AVS › AVS Forum › Audio › DIY Speakers and Subs › Do I need to seal around sub's rim?
post #1 of 5
Hey,
I have almost completed the first of a few TC LMS 18" sub boxs and I am ready to bolt the woofer to the box. Do I need to run a silicon bead around the the rim of the sum or will the rubber be sufficient for a seal. Also should I run a bead of silicon around the inside of the box? I used rabbit and dado for joinery.
Cheers
post #2 of 5
Yes, I would run a bead around the joints inside the box. No I would not run a bead around the rim of the driver. You may want or need to remove the driver. The rubber seal should work fine on the driver.
post #3 of 5
Definitely don't use silicon on your drivers to get a better seal, as Mike has already said you may need to remove them and you would have a horrible time.
I would actually remove the rubber gasket and use this instead: http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-542
Rubber gaskets can leak so I always remove them and use the gasket tape for a airtight seal. I got this tip from Bossobass a long time ago who is one of the most knowledgeable sub builders on this forum.
post #4 of 5
Thanks for the comments guys.
I really did not think that I would need to put a bead of silicon around the inside of the box, especially with the joints I used and the amount of glue and clamping. I would have thought the wood glue would have provided a good seal. What would the effect be of a very small leak?
post #5 of 5
You really do not need to use silicon. What most people do is run a bead of glue and then smooth it out with your finger.
