So I moved into a new house, and will be using my Yamaha RX-V765 receiver to power my new home theater in the den/family room, and will be using my BIC F12 sub. It is 15x15 room with the back being partially opened to the kitchen. I need a new speaker system for this house (the monoprice in wall and in ceilings worked great at the old house but wont work in the arrangement I want to do in this one). I wont listen to music that often on them, as they would be primarily used for movies and watching TV. So I think I have narrowed it down to the following:
Either:
Energy Take 5 speaker system (seems to be different models? depending on year made, at least they look different without the grills on)
OR
BIC DV-62CLRS Center, BIC DV62si for fronts (will be sitting in custom bookcases), and BIC M-SR6 in the ceiling for the rears
I was also looking at the BIC FH6-LCR for the center but I read that horns and dome tweeters shouldnt be mixed for the best results.
What do you all think? When I was putting in my old system you all gave me great advice regarding amps/speakers. Thanks in advance!
Either:
OR
