AVS › AVS Forum › Audio › Speakers › Moved and need to redo home theater speakers
post #1 of 12
TV is now in the basement of the new house. Previously had in ceiling speakers that were great but wont work in the new space. I am sticking with my Onkyo TX-SR506 receiver with Yamaha NS-C225 center channel for now but need some floor standing speakers for fronts and then something I can hang from the ceiling corners for rears (bookshelves or satellites). Help me find something solid for under $500....
post #2 of 12
These:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117403
These:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117406
This center. I would not use the existing center as you want to timbre match your main speakers:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117404
This sub:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026
Right on budget.
post #3 of 12
Forgot to mention I still have my TSC subwoofer from the last setup, so no need to add one. Not a huge fan of the look of those Pioneers to be honest, great pricing though
post #4 of 12
post #5 of 12
Well, the new series looks better to me (subjective) - however, they also have really
improved the sound >> and will hold up against some more popular and expensive
name brand speakers. I do like the sound.
Audioholics Cedia show report - move down the page
http://www.audioholics.com/news/trade-show-coverage/2012-cedia-show-report
Edited by zieglj01 - 9/15/12 at 9:34pm
post #6 of 12
The Pioneers do look better without the grills imo, love the reviews and pricing.
Those Polks should be perfect for the rears.
The reason i went with the Yamaha center was that is wasnt high at all, we only have about 6" to work with height wise for the center channel because it sits infront of the TV. The Polk center might work as it isnt to high. I'll put something on top of the yamaha and see how much extra room we can use
post #7 of 12
Polk Monitor50s for $160 or the Pioneers for $140? I think the Polk rears will work better for me
post #8 of 12
Reviving this thread. What do you think about these energy speakers? Would they pair ok with my onkyo receiver current center (Yamaha NS-C225) and the polk on wall for rear (http://www.amazon.com/Polk-Audio-On-Wall-Speaker-White/dp/B0018QNYXA/ref=pd_bxgy_e_text_y)
They look like a great deal and have nice reviews
http://www.newegg.com/Product/Product.aspx?SID=ylMxPBDVEeKfd85lAEKLqQDs12_0_AnJ_0_0&AID=10440897&PID=1225267&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-cables-_-na-_-na&Item=N82E16882269036
post #9 of 12
I would still prefer the new Pioneer speakers - and I would mate them with a Pioneer center.
post #10 of 12
The pioneer center is to tall to be infront of my TV, so it just wont work. This yamaha center was the only non-soundbar one I could find that was short enough. Even the polk CS1 centers are to tall
post #11 of 12
Have you thought about a TV Center shelf-mount?
http://www.crutchfield.com/shopsearch/tv_center_shelf_mount.html
post #12 of 12
I hadnt seen these before. i was also thinking of making a little box to raise the TV up a couple of inches as well, but not sure what would be best
  Back to Forum: Speakers
