Tectum Panels
post #1 of 2
Has anyone worked with Tectum panels? I have a friend that has a bunch left over from a commercial job. 2" thick, 2x4 panels. Was thinking about using them behind my AT screen wall with is about 14ft wide x 2 ft in depth. would they also work good as bass traps in the corners? Also, if I used them in the finished room, I could cover with fabric.
post #2 of 2
They've got full specs on the web. Sound absorbing coefficients here.
They can be painted, which may be an alternative to fabric. The texture of the panels is interesting.
