We finally got FiOS TV in our area and my box of equipment just showed up at the front door. (It's a self install situation since we already have FiOS phone and internet.) I was hoping that, like some other providers, the set top box for the secondary TVs attached to the whole-house DVR would be small enough to fit behind the wall mounted TV in the bedroom. It is, however, quite large. I can mount it remotely (my closet) and use the cabling I put in the walls during construction to get the signal to the TV location, however, I only have the following to work with: two RG-6, two speaker pair, one Cat 5e. Is there a good solution to pump component video over this combination? I was thinking the two RG-6 fitted with RCA plugs could handle two of the three component channels, but can the Cat 5e be configured in such a way to handle the third? Obviously the audio will run on the speaker pairs, but this third line for video is what's stumping me.
Any suggestions?
Any suggestions?
