... for the most part.
As far as I can see, the only thing you are getting from an Anamorphic Lens with a Blu-Ray source compared with simply zooming is more brightness and the ability to have a wider image if the zoom on your projector isn't enough.
I can only put my projector about 14 feet from the screen, which I sit 10 feet away from. A 120" wide image is about the limit of even the most versitial zoom projectors without an anamorphic lens. I'm thinking a $2000 hunk of glass isn't worth it to go a few inches wider, because I don't need the extra brightness, and as I said above... you DON'T get any resolution benefit from it.
Ok, what am I missing?
