AVS › AVS Forum › Video Components › Home Theater Computers › MPC-HC prioritized audio.
post #1 of 5
Hello,
I just recently installed MPC-HC and followed the Advanced MPC-HC Setup Guide but am having some trouble. Whenever I play a video with MPC-HC, it switches the audio stream (To one of the external audio renders I assume) and I can only hear MPC-HC, Any other program such as Skype, Foobar, or my internet browser do not function with audio until I close MPC-HC. I would like to know what settings I must change to have it play without singling out the stream. Sorry if this has been posted elsewhere, I failed to locate anything with the search function.Regards
post #2 of 5
I had the same problem with WMC: http://www.silicondust.com/forum/viewtopic.php?p=77443#77443 Here is where the button is:
post #3 of 5
Thanks for the reply, Other applications can run with sound now but MPC-HC shows a pop up "Audio device is in use" and has no sound. Suggestions? Thanks
post #4 of 5
Sorry, I don't have MPC-HC installed on this machine yet so I don't know.
post #5 of 5
I installed MPC-HC last night and it works through the mixer just fine. Perhaps you've changed one of the defaults in it? There is a 'restore defaults' that may help. If not look around in Audio Options for a possible solution.
