AVS › AVS Forum › Audio › Receivers, Amps, and Processors › sony str de 345
sony str de 345
post #1 of 2
found thisd in garage..cost 400..question..can this be used for 2 channel music...anybody
post #2 of 2
This is an older receiver with no optical or digital coax inputs so it doesn't decode Dolby Digital 5.1 or DTS. It does Dolby Pro Logic by taking a two channel signal and mixing it into 5.1.
This receiver will be perfectly fine for two channel use. Just connect your speakers to the front left and right speaker terminals.
