AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › BenQ W7000 lens shift joystick poll
Poll Results: After I have "locked" my lens shift knob by tightening it clockwise:
Poll expired: Sep 21, 2012
  • 0% (0)
    When I apply pressure to the lens shift joystick, there is no play at all, the lens does not move.
  • 100% (2)
    When I apply pressure to the lens shift joystick, there is a small amount of play (i.e. 5%) before the lens becomes immovable.
2 Total Votes
post #1 of 4
Hi all,
So I was having a problem because my lens shift knob on my W7000 would not turn, now I got it to turn however when fully tightened I can still move the joystick about slightly (i.e. 5%) before the lens won't move.
I looked online and projectorcentral I believe in their review stated that when the lens shift is locked on the W7000, the lens still can move a bit. Another post here indicated it did not move at all.
I wanted to see if the small amount of movement I get when the lens shift is locked is the norm, i.e. if some units have this other than mine perhaps like Projector Central's. Basically when I "unlock" the joystick, I have full range of motion of the lens. When I "lock" it, I still can move the lens slightly (say 5% of full range), but after that it is locked. So I wanted to see if some of the units have this or if there is definitely a problem with the lens shift knob on my unit. Although, if the lens does not sink or anything this might be a non-issue.
post #2 of 4
I went back and checked this closely tonight. With it fully locked, if I apply some pressure, I can get it to move a bit up and down. It's not going to shift on it's own if I have it locked in that position though...
Do you think it will drift on it's own with your particular situation?
post #3 of 4
No, it doesnt look like it is drifting so far, and if it does it would only be by 5% or so. I just want to make sure this was normal behavior because something was misaligned with the knob out of the box and I had to force it into the right position. It appears to be working now though so should be okay.
post #4 of 4
I checked again with the projector on, it's definitely the same behavior you are seeing. It's locked tight, but there is a little bit of play if I try to move it around. It's never drifted on me.
