AVS › AVS Forum › Audio › Speakers › old infinity bookshelf speakers
post #1 of 9
background:
so i just got the pioneer package (fs51, c21, bs21) a while back. i plan to use the 51s and the c21 as the front stage but due to space, i got 4 mirage nano sats and mounted them from the ceiling to complete the 7.1 with a klipsch rw12d sub. the denon 2112 does not allow for front heights or front wides, but maybe someday i will have a receiver that allows for that.
so basically i have 2 pair of bookshelf speakers that will not be in use, which pair would be better to keep for potential front wides? they are:
pioneer bs-21 series
infinity reference 2000.2 series
the bs-21s have smaller drivers but are newer and are timbre matched to the front stage, but not timbre matched to the surrounds. the infinitys have 6.5" drivers but are older and are not timbre matched. thanks
post #2 of 9
bump, thanks
post #3 of 9
here are the infinity's
post #4 of 9
I would sell the Infinity speakers, and keep the Pioneer speakers. I prefer that
the front wides, blend with the front stage.
post #5 of 9
ok, thanks
keeping timbre matching aside, which is the better speaker, one on one?
post #6 of 9
Originally Posted by mgrotel View Post
ok, thanks
The Infinity will sound bigger and have more bass than the BS21 - however, I do not
like the Infinity cheap poly-carbonate tweeter.
post #7 of 9
is the tweeter really that bad in the infinity? what is so bad about it? what does a poly-carbonate tweeter sound like? thanks
post #8 of 9
post #9 of 9
dont have a receiver to use, well, i do but its packed away behind a bunch of crap until the basement is finished. even if i could get it out, i dont think my ears are trained well enough to tell a difference, im just trying to learn on here. thanks
  Back to Forum: Speakers
