Well, I have my front height & wide speakers mounted.
Here is where I am and what I want to do:
-I've attached all the speakers wired to their labeled positions, expect of course the Front R/C/L are attached to the XPA-3
-I want the zone2 attached to the Fronts, so when I have sports night will run "just 9.1" and the 2 amps will then play over the pool table
-I've atatched zone2 speaker to the fronts
Last night was going thru what I thought was a no-brainer;
-go to custom amp
-set the front/center to pre-out, as I'm using a Emotiva XPA-3 for them
-set the un-used front amps to zone 2 so they can power the nearby rec-room when I want that for sports events
(and realize the HT will go to 9.1 then)
Sounds simple.
I'm either dumb as mud, constantly distracted by my 3 kids, too busy to read the pdf only manual (which I've started via my iPad), or "xxx" (type your answer there
I realize I have 8 amps to use, the center can't be re-assigned.
First the auto speaker routing gave me this when I went thru it and told it I have 7.1 + wides/height:
That as a start, but desired to shut off the Front/Center, and assign the front to zone2 for driving the speakers above my pool table for game night action
So, I went thru the various choices:
This look like on the right track, but I could NOT put zone2 onto the fronts, like a "free assign, physically there for zone2 usage:
I then did this, that was weird, it ping the speakers above the table, like zone2 was part of the main HT EQ process
It was getting late, so I settled on this choice, and then ran the Audyssey XT32 routine and called it a night.
I was kinda geeky cool to see it go thru all the 11.1 speakers
Been busy this morning, church/etc, so will see if I can go to zone2 and what 2 amps go to that.....
Others here with 11.1 speaker set-up and a zone2 that you want to power off the 4520 amp (and then your HT will be 9.1) what did you use?
