Originally Posted by
avatar9
Yes there is with internet radio on, and different source selected. The hiss gets pretty audible close to the speaker especially at 6.0 and above. The hiss is barely present at 0.0 but if you listened all the time at 0.0 dB with no source on it may get to you.
avatar9
I am surprised just me and Joe6p are the only ones. It is really obvious to me (but I have been careful with my hearing mostly). I have a separate power circuit that only runs to my avr and HT equip. and another separate circuit that runs the pj. I have nothing else powered on, except my timewarner samsung DVR which is always on. So maybe it's the cable box, I can go check now and I just might since everyone is claiming complete silence.
Dreamliner
I've got a 4311 at the moment, currently waiting for my 4520. I know its a different model, but I can hear hiss with the volume all the way up (+15). I can also faintly heard the HD radio bleed. This is even on a speaker that is only a few feet from the receiver as well as the farthest one. The 4311 is certainly modern, but mine hisses, too. At 0.0, its silent. No way has this ever affected my usage as its almost never over 0.0, and its usually playing something when it is.
avatar9
Definitely not coming from any other source. I unplugged the rest of the equipment the entire circuit only powers the AVR and the hiss is still there plus the radio or internet radio doesn't need to be on for this hiss (and changing tuning does not help. I am perplexed but not very bothered by this, as I never listen to it that way. Besides some gain sound may be normal at these volumes; But if you did sit back with this thing cranked to max and just listened to an empty source channel you could go crazy.
avatar9
I do not get any bleed through at all though just hiss and same experience here minus that bleed. I think no biggie.
Theresa
I used to obsess over FM radio hiss and multipath. I let it make me crazy. Eventually I just got a roof top antenna and rotator. But now even without such a fancy antenna I don't let it bother me. Like I said, at the volumes I listen to it, quite loud, there is no hiss or bleed through. Turning it up to max volume just to be bothered by hiss is a useless exercise.
Dreamliner
Agreed. 100%.
If I could hear anything but silence at say -10, I'd have reason to complain. I bet the Marantz 8801 is better in this regard, but it is of zero consequence to normal, or even higher than normal use.
Now, my old car stereo had audible FM between switching tracks on the MP3 player.
Thank you all for sharing the information.
Just for the record let me reiterate this: My previous set up Denon AVR-5803 mated with Denon DVD-5900 at max volume in any configuration sounded absolutely dead silent as if they were turned off. (No FM/AM antennas connected though.)
Also, my observation about the OPPO’s lip-sync problem was also met with resistance until I proved it scientifically and pinpointed it at 180ms…..
I spent over $75k on my home theater over the years not just to show off but to enjoy quality audio more than anything else.
Having said that, Just like my experience in high-end/performance cars, they all come with bugs not that they were made cheaply but that’s what we expect from leading edge technologies. In many cases the consumers are the ones testing those innovations.
As long as we know that, there is no reason to live in denial or feel ashamed of it.
And I must admit, my passion is to test my equipments to their limits so I can testify to their capabilities first hand.
Cheers again…
