Originally Posted by Nameless_87
I tried another HDMI cable as I had a spare one (high speed) and same problem
Then I tried the Reset PS3 method...
I noticed some things... The screen appears in 576p saying that it found an HDMI... when I press yes, nothing... black screen again.
I tried it a second time and same thing happens, then I tried switching input and back to GAME input and it appeared with the message 1080p, do you want to keep... I say yes and everything seems fine.
I turned everything off then and started normal power up... TV, AVR on correct input and then PS3 and nothing is visible, just blank screen with STEREO audio... I change to another input and back to GAME and screen comes on for 1 second and then turns black again...
I tried to connect the HTPC(1080p) and Dreambox (1080i) to GAME input to see if the problem is with the AVR and both worked good... I played Avatar on HTPC and played flawlessly as well!
At this point I have no idea what to do and I don't know what the problem is!
Any help
Any help
Did you check the hdmi cable from Ps3 to Recv, from Recv to Tv, Also make sure that the Recv Video up conversion is NOT! set on 4k ,if it is you will not get a Signal!!
It's true that HDMI sounds pretty darn good, as does analog from top players.
I have no Issues with my Ps3 to my 4520 in the Game input , output to my Sony 1080P LCD, Everything works Flawlessly as it should.
