AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** DENON AVR-4520CI thread
The **OFFICIAL** DENON AVR-4520CI thread - Page 103
post #3061 of 4491
post #3062 of 4491
@nezff
@jdsmoothie
@a1usedcomp
post #3063 of 4491
Originally Posted by tkroeker View Post
Hey guys,
For those of you who have set up all 11 speakers, did you set up the heights according to the Dolby or Audyssey diagrams? Has anyone tried both options and have any preferences?
I went with Audyssey.
You can see how it looks in my signature...
post #3064 of 4491
Hey guys,
I run heights and have tried both. It's a matter of taste really. Audyssey DSX derives the Height information from the front L&R channels, reduces the levels of those channels by 3dB and decorrelates the surrounds and also reduces the levels by 3dB. This gives a very front-centric presentation - a 'wall of sound' - which I personally dislike. Dolby PLIIz derives the information for the heights from the surround channels and preserves the ambience of those channels. I find the latter to be more pleasing. Also., Dolby is not nearly as demanding of speaker placement as DSX. DSX was designed to create a greater sense of ambient space which is specially good for music where I feel Dolby is more orientated towards movies, which is what I want.  Try both if you can and go with the one that sounds best to you - it is all about preference in this case, not reference.
post #3065 of 4491
Thank you for the input guys!
Tim
post #3066 of 4491
What are people thinking of DTS NEO X?
post #3067 of 4491
Well I have been using this receiver for about a week now and I absolutely LOVE it!. I replaced an older Denon 4306 that did have Audyssey as well, however I never ran with it on because I did not like the results. After running the Audyssey setup on the 4520 and adding 2 additional rear surrounds for a 7.1 channel setup I find myself watching my whole movie collection again. It really sounds awesome. I'm driving an old pair of B&W 640I as my mains with 610i's as the rears, an ASW 1000 sub and LCR-S2 center. My dream speakers would be the B&W 803's and as soon as 10K falls into my lap I'll get them :-)
I do miss the icons for input and output on the display. I also wish it supported party mode as I have a 2112 for outdoor music that I'd like to synch with the 4520's zone 2 driving the kitchen speakers with the 2112 driving the outdoor speakers. But I'll live.
post #3068 of 4491
DTS NEO X is what I am using 95% of the time.
post #3069 of 4491
Has this review been posted from Home Theatre Shack?
http://www.hometheatershack.com/forums/av-receivers-preamps-processors-amplifier-reviews/65664-denon-avr-4520ci-receiver-review.html#axzz2LUPx123j
For those wondering about how well the amps run it might help?
Also interesting comments on Audyssey setup. I have found that simply running three positions of my sofa (its not a dedicated room, so it's nothing like what a lot of you guys have) yields a better result than running all eight. Thinking of getting REW or something like that to see what's going on.
post #3070 of 4491
What about running all 8 positions from the same sofa? Or does that get picked up Audyssey?
post #3071 of 4491
I run it for everything (I have an Onkyo 3010, but it runs the same NEO:X). I am running a 9.2 setup with front heights.
post #3072 of 4491
I haven't set mine up yet but from what I have read, when going with 9 speakers the recommendation is to go with wides vs heights. In my layout that's the only realistic option given limited ceiling height.
post #3073 of 4491
To add to this, there simply is no manufacturer that can guarantee a 0% fault tolerance rate on their products. There is always that one unit that passes QA that for whatever reason just fails. That might be one of the reason a lot of manufacturers in the audio world have 5 year warranties on speakers, and typically 2-3 years in electronics. I noticed the 4520 now has a 3 year warranty. I believe Denon AVRs typically have 2 years.
Given this flagship status, I would imagine Denon service should take care of you without much grief.
Hello,
My dealer has ordered a replacement AVR-4520CI that hopefully will arrive by next week. In the meantime, I just have to be careful not to raise the volume level that high or change sources too often.
Cheers,
AD
post #3074 of 4491
sticking my head in... things haven't changed i see...
mine still works...
fwiw, my home theater obsession is over, and have moved on to a new obsession... therefore, a lot of my goodies (video cal equipment, audyssey prokit, radiance mini, etc.) are available... if anyone is interested, pm me...
post #3075 of 4491
Originally Posted by FlatRocky View Post
Any one has success using direct airplay on this receiver? i had this receiver showed up once in the airplay speaker list but never after. i called Denon and LOL it was an experience with the worst attitude problem that i got from an on line help person, and will never call denon again. and will think twice before buy Denon LOL.
i tried different solutions including IGMP on/off but nothing is working with WNDR3700 netgear router. Denon is hard wired and it is on the network. i can see rest of the airplay Speakers but not Denon.
Thank you in advance.
Yup I use Airplay daily...works pretty good...except for the slight lag between button presses on the iPhone and the Amp recognizes it...
post #3076 of 4491
All Denon "CI" models have a 3 year warranty which went into effect with the XX11CI models 3 years ago.
post #3077 of 4491
Watched Dredd last week, it is 1 of 2 movies encoded in DTS NEO X, which sounded great on my 11.1 system.
The movie itself...so so.
Sent from my 32GB iPhone4 using Tapatalk
post #3078 of 4491
Hi everyone, in case somebody else runs into the problem I ran into last week, I found a solution.
My problem was that I had received a Firmware update notification. When I try to proceed with the update, it failed for some reason. Ever since that, my receiver was always telling me I had the latest firmware even if it was clearly not the case. I tried every day ever since and the receiver was always telling me I had the latest. I tried setting the network setting from Alwyas ON to Off and it didn't make any difference.
Yesterday, I had a power failure at home. In the evening, I tried again to do the firmware update and the receiver finally saw the update and applied it.
So if you have a problem updating the firmware, disconnect the power from the receiver for a little while, it will probably fix the problem.
Hopefully this post will help somebody at some point.
post #3079 of 4491
Well, I just got my 4520 setup, coming from a 4311. My initial impressions:
I've only watched Argo and a bit of TV, so nothing too exciting yet, I will say, I like the AUDIO a bit better. I can't say for sure if the audio quality is better, it could just be in my head, but I think it sounds a bit better.
One think I know I noticed: On my 4311, if I muted an input and turned the volume to max, I could hear a hiss from all my speakers; the 4520 is absolutely silent. With the noise floor so low on the 4311, it was never an issue, just something of note. Its nice to hear nothing at max volume on the 4520.
Here's my rant list, which is a bit odd for me, as my only complaint when I upgraded to the 4311 was lack of switched outlets:
1) The display looks very cheap compared to the 4311's.
2) I really miss the IN + OUT signal display.
3) Miss the glowing ring around the power button.
4) Am frustrated at the odd height. The 4311 was exactly 3RU tall, with a vent plate above it, it fit in my rack perfectly. The 4520 is ~3.5RU tall, they don't make ~1.5RU vent plates.
5) I miss the Channel Level Button. I'd occasionally adjust the sub woofer or center channel depending on content, it was fast and easy. I did find a separate sub woofer level control though.
6) Can't cycle through sound modes by pressing a button under the display.
7) Pressing the power button doesn't shut it off, it just switches the zone off...?
I don't care a TON about the aesthetic items as the receiver is in a equipment rack in a different room. I just thought I'd mention my impressions.
I do have a few quick questions:
A) How the heck do I shut this off without a remote?
B) How do I switch between sound modes (DTS-NEO:X, Audyssey Height, Auddyssey Wide, Direct, Stereo, etc) with the remote? (As there doesn't seem to be a button on it anymore)
C) What are your thoughts on Dynamic Volume/EQ. I've always thought of these as 'compression' which eliminates dynamic range....similar to how a lot of new music is mastered.
D) How do I pull up the signal in/signal out information on screen?
post #3080 of 4491
I'm hooking mine up tonight. Going from a 4311. Can't wait!
post #3081 of 4491
I've only had it set up for a week but I think I can address one of your questions.
A) I haven't explored this yet but it's on my radar. Sorry, can't help on this one.
B) If you hold the "music" or "movie" buttons for 5 seconds an on screen menu pops up. Keep hitting the button to change sound mode.
C) I like it because I have sleeping kids and I watch my movies at night. If I am by myself it is off.
D) Can't help you there. Sorry.
post #3082 of 4491
Im asuming before running audyssey, I will put the unit in pre pro mode. Do I need to assign anything else
post #3083 of 4491
Dynamic EQ isn't the same as compression in the sense I believe you mean it (although Dynamic Volume is). Check out the Audyssey FAQ, here:
g)1.   What is Dynamic Volume?
g)2.   What is Dynamic EQ?
g)4.   What's the difference between Dynamic Volume, Dynamic EQ & Reference Level Offset?
post #3084 of 4491
C) What are your thoughts on Dynamic Volume/EQ. I've always thought of these as 'compressioput n' which eliminates dynamic range....similar to how a lot of new music is mastered.
I wouldn't say the display looks cheap, they omitted some details but in the process details that are there are legible from a further distance. Nevertheless, I do miss having both the input and output channels displayed. My solution is to pick the input channels - that way your decoding choice will tell you what you need to know about channel output (e.g. stereo = 2 channel, DTS-HD + PLIIx = 7 channel, etc.). Most AVRs I've come across typically only display the input channels anyway.
You miss the glowing ring around the power buttton? That I dont' understand! Personally, I think the fewer visual distractions from what's on my display the better.
Regarding dynamic EQ, if you listen at anything below reference (i.e. 0 db) I think it is invaluable - in fact I wouldn't buy any receiver that didn't have Dynamic EQ though THX Loudness Plus is decent too. As for Dynamic Volume, whether you need it depends on your personal circumstances. I have three young kids and Dynamic Volume allows me to listen at low volume levels at night without completely crippling the dynamics the the way typical dynamic range compressors do.
post #3085 of 4491
Make sure all zones are pushed off on the left side of the front panel.
post #3086 of 4491
A. Press the Standby/ON button to place in Standby ... to power OFF it must be unplugged.
B. Press either MOVIE, MUSIC, or GAME and hold for a few seconds until menu displays on the TV.
C. Dyn EQ for all sources, all the time. Dyn Vol for TV and late night viewing only.
D. Front Display -- Channel Indicators -- Input/Output (p. 153 OM).
post #3087 of 4491
D. Setup Menu > General > Information > Video > HDMI Signal Info.
D. Setup Menu > General > Information > Audio
post #3088 of 4491
It stays in active standby if either Zone 2, 3 or 4 is active. Otherwise it turns off when the power button on either RC or the receiver is pushed. (What I mean by off is all displays off but the RC through IR or WIFI in standby mode ready for command to turn the unit on.)
Speaking of unplugging the AC cord, I did a deep rest on mine a couple of days ago because it was acting up. I finished calibrating it and setting it up. I turned it off. Next time I turned it on, it ignored the HDMI input (no audio or video) only internet radio worked. I tried turning it off and on in vain and I was about ready to reset it again until I thought about unplugging and re-plugging. That fixed the problem.
Reminds me of Microsoft Windows…
post #3089 of 4491
Did someone notice any significant changes with the latest firmware update?
post #3090 of 4491
Originally Posted by AustinJerry View Post
I would return/exchange it as well.  There haven't been too many reports of hardware issues.  However, my first 4520 had a dead surround channel, and I was forced to ask for a replacement.  Nothing wrong with my current 4520.
I’m aware of another case with a bad center channel amp DOA.
My guess those are bad power amps modules that can be interchangeable.
The good news if you’re not using all of them you can exchange modules internally as a last resort. In my present configuration there are three channel amps in my unit I’m not utilizing.
