Originally Posted by PepperOne
1. I guess that my question needs better clarification. When I connect the speakers and sub, and turn on the 4520, will I be able to hear any audio if I say have the AVR set on a FM station before I employ Audyssey?
3. You said that there is no default setting for the amp assignments. Does that mean that in question 1 above means that I will have no audio output with a FM station tuned in and that the amps need to be assigned before any speaker output is detected?
Gerry
Originally Posted by batpig
1. Yes, Audyssey isn't required to produce sound. It's a calibration program.
2. Um... this is the same question as #1
3. No, there is a default assignment.
4. Yes, keep it at approximately ear level for all measurements.
5. Not *necessary* but you should run all 8 positions to feed the system as much data about your room as possible
6. In addition to the above, read through the Audyssey info I've aggregated here, it would have answered questions 4 & 5 also: http://batpigworld.com/wp/?page_id=37
Gerry
Gerry,
1. No, it was perfectly clear and it's still the same question as #2
Audyssey setup is NOT required to hear sound, period.3. Um, read what I wrote again
There is a comma between the word "No" and the rest of the sentence.
Chris from Audyssey confirmed this... apparently Onkyo felt that, due to the number of false positives, it was something that ended up being more confusing than helpful for the end user.
I just wanted to thank Mike @AVS for all the help in getting me a replacement 4520 from Denon! The new one is working out so far and everything is back to normal.
The audio continues to come through just fine during the blackout. I have hooked up 2 DVRs (Comcast Motorola 3416s) and 1 HTPC. All three were hooked up via HDMI. I also tried hooking up the DVRs via component and get the same issue. I have tried swapping the HDMI 1.3a cables for new 1.4 cables with no luck as well.
