I upgraded from the 4311. I only really miss the channel level quick setting.Originally Posted by Djoel
Anyone here made the jump to the 4520 from the 4311 and regretted whether it be for the lack of the tiniest feature/s, not happy with the remote etc , or happy as a clam by their decision.
Or should I just save my money being that I own a 5.1 setup.
Oh before I forget I know you can do a comparison type chart over on the Denon site, but is there one here on the thread.
Djoel
Djoel
I have 11.2 and upgraded because I wanted Neo:X. If I only had 5.1, I wouldn't see a reason to upgrade.
You should get some more speakers.
. Even then I'm not sure if I would switch from the 4311. I think you should hold on to your 4311 and spend the upgrade money on SACDs
you can here 3-4 houses down the Street
