AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** DENON AVR-4520CI thread
The **OFFICIAL** DENON AVR-4520CI thread - Page 175
post #5221 of 7861
Originally Posted by mhrischuk View Post
Looks like I got bit buying a refurb.
First ZONE2 stopped working. I unplugged the unit and it started working again.
Today it stopped and unplugging it does not fix it.
NO ZONE2
I'm past the 30 days for Accessories4less. Going the warranty route.
SUCKS
Since you are having problems... I would consider buying the extended warranty from them too.
post #5222 of 7861
Wow! Great review, thanks!
post #5223 of 7861
post #5224 of 7861
You are the king of the German language review John smile.gif Do you speak German or do you just lurk on their A/V websites? tongue.gif
post #5225 of 7861
You can't ignore the wealth of AV knowledge that UK/Europe magazines and reviewers offer, add the fact that you can have any web page translated doesn't mean you need to speak those languages. smile.gif
When we are capturing all the various reviews of the Oppo Digital players you see a very international representation of AV reviews, should that be any different with Denon AVR reviews? tongue.gif
Edited by JohnAV - 7/29/13 at 12:23pm
post #5226 of 7861
NO ZONE2
SUCKS
Do you have a 2012 model or 2013? (Serial Number starts with a 2 or 3)
post #5227 of 7861
Starts with 2
Yesterday came home and tried ZONE2.... it worked.
This is after spending probably an hour the day before going through just about every scenario I could think of to get it back on with no success.
I'll play with it fo a while and see if it continues to work.
Re-cap..
Originally I added a set of ZONE2 speakers last week. I configured the amps using custom so I could turn the front L/C/R amps off (active speakers) and use the AVR amps to drive my 4 ceiling surrounds and ZONE2.
I set Surround wide to ZONE2 which indicates that those speaker terminals be used for the ZONE2 speakers.
Initially I got no sound except from an analog source so I discovered, with help from here, that I needed to hook up RCA audios for all sources being used on ZONE2.
That worked and I was happy.
Next day I turned the system on and ZONE2 would not play. I changed input to Zone2 than back to the original input and ZONE2 began to work again.
Next day could not get ZONE2 to work at all no matter what I did.
Yesterday it just started working.
Edited by mhrischuk - 7/30/13 at 4:04am
post #5228 of 7861
NO ZONE2
SUCKS
Sorry to hear of your problems. However, this is why I try to always buy new gear. Saving 10 - 15% on a refurb. over a new unit isn't worth it to me. That said, I hope yours gets fixed quickly, and 100%.
post #5229 of 7861
We'll see how it goes. Right now, it has fixed itself. Very weird as I made no changes.
I will see if it keeps acting up for now. Until then its staying hooked up.
Edited by mhrischuk - 8/7/13 at 4:19am
post #5230 of 7861
Fooled around with the system today. So far so good. Zone2 is working flawlessly, changing sources, switching main to off. Trying to break it but can't.
post #5231 of 7861
Hey guys. I really like this machine. I feel I may really have a home theater. I feel a little confused though. Hope someone can help shed a light. I'm running 9.1 right now with front heights. I feel the auto setup has everything setup pretty good. I've played with manual setup too. Pretty cool gui and all.
Anyway, all these different sound fields, I feel I might be missing something. I know that if I hold the green button on the remote it allows me to change settings. Just not sure which is best for the 9.1. I'm sure not any of them are 100 percent real. Something has to be created from at best 7.1 input. But I see fields I've never heard of.
Seems I read something about the Neo:X. That was one reason I got the Denon 4520 in the first place. But things like:
Neo:X Cinema(Back/Hieght)
Dolby Digital A-DSX (height
PLIIx Cinema A_DSX(Heigh, And so on. Seems like some of them have to do with the Audyssey.
So what do others use. OH. For movies for the most part too. Is there one setting that seems to be more realistic than others..
And if my serial number starts with a 3, does that mean 2013, and is that a good thing?????
post #5232 of 7861
IMO, you need to experiment with the various surround options.
I prefer Neo-X DTS over Audyssey's iteration.
As for year of make, I was an early buyer, but I had no issues and I am still using the first FW. I see no reason to upgrade that. A later make probably means more bugs are sorted I guess.
post #5233 of 7861
Seven months of faithful service and counting.
post #5234 of 7861
+ 1. I have been using DTS NEO:X for a while now. I like it. Skyfall in 11.1 last night had a couple of friends yelling " that was awesome " during the movie when cars and explosions went roaring across the entire front soundatage. !!
post #5235 of 7861
As already suggested, which surround mode you choose should be based on personal preference, although as the majority of movie audio is still only 5.1, in those instances the rear surrounds must be simulated for 7.1 using either Dolby's version (DD PLIIx) or DTS's version (DTS: Neo:X) and then to add the Height speakers for 9.1 you can use either Dolby's version (DD PLIIz), DTS's version (DTS Neo:X), or Audyssey's version (DSX). Although Audyssey's DSX only adds either Height and/or Wide speakers, the new Audyssey DSX 2.0 can simulate up to 11.1 from a 2.0 source just as DTS Neo:X.
And yes, the 1st digit of the serial number indicates the year it was mfr'd (eg. 3 = 2013) and the 2nd/3rd digits the month (eg. 02 = Feb).
post #5236 of 7861
Ok then. I feel much better. I thought I was missing something somewhere. It just seemed too simple. I guess its just that good of a machine.
Thanks for the help.
post #5237 of 7861
Is anyone using a wireless transmitter for their surrounds? I was hoping to use some active speakers I have lying around with my 4520 and was wondering if anyone had done something similar?
post #5238 of 7861
I have tried a wireless connection for my subs and it didn't work well--too much interference with the 20 devices I have on my home wireless network.  Too many pops and crackles.  You might have success.
post #5239 of 7861
Just got that marvellous phone call to say my new AVR has arrived. Will be picking it up tonight and have a wife-free, 4-day weekend to play with it. biggrin.gif
post #5240 of 7861
Enjoy the avr. Sure has brought my ht to life....
post #5241 of 7861
Ok, time for the next step. 11.1 Any one suggest a good amp to go with this avr.
post #5242 of 7861
No wife, cool new toy=cool weekend!
post #5243 of 7861
An old AVR can do to start, if you have one not being used.
post #5244 of 7861
Is there any chance the problem isn't actually in the receiver?
In other words, might the connections to the Zone 2 speakers be unreliable?
Or could someone have been "adjusting" them?
post #5245 of 7861
That's so funny. I was thinking I didn't have anything just laying around. Forgot about the Sony I just pulled out where the Denon went....I might try that just to see what it sounds like. Thanks.
But, I'm sure i'll like it, seeing I do have the speakers. I guess as for the amp. I'd at least want a 2 channel, 150 watt each channel, to try to match. I might even look for a 3 channel to cover the 3 fronts, and take some pressure off the Denon.
But being new, never had anything this nice. I'm really needing some others to help guild me on this one. I'm trying not to spend more than I need to. And not wish I hadn't planned my system better. So far, I think I've done pretty good.
Thanks again for any and all the help. This forum has probably been one of the best complete forums I've ever ran across......
post #5246 of 7861
I use an Emotiva XPA-3 for the front speakers and the 4520 for the remaining eight speakers.
post #5247 of 7861
I bet that works well Jerry. I'm using an Emotiva XPA 200 to run the front L / R speakers. I tried to watch Skyfall the other night with the sound at 82, and my two loud movie loving buddies told me to turn it down ( I settled around 78 ). I imagine a lot depends on your room / room size and speakers.
post #5248 of 7861
So, I got the 4520 home and set it up. Ran through the set-up wizard and Audyssey. Only problem I had was with the subwoofer. It wasn't working, then I realized I hadn't turned the darn thing on. Configured most things and got the volume display to show up like I'm used too. Watch the first few minutes of Revenge of the Sith on Blu-ray--my go-to test. Seemed much better than my 3808 and had all the clarity I remember and would so very much miss from my Anthem MRX-700. It's now updating the firmware. So far I'm happy and relieved to have a receiver that isn't causing my speakers to hiss and pop when I turn it on and off. Like the binding posts and the look. Not as large or as heavy as I thought. Am looking forward to connecting my DVD-3930CI when I buy some analog cables. It's been gathering dust hooked up to the 3808 via Denon Link. I've been using my Oppo via HDMI to play SACD's with the Anthem, and am looking forward to hearing analog audio again. Tomorrow I'll skim the Denon to English dictionary and make sure it's all set-up as I want.
post #5249 of 7861
One thing I wanted to add. With ARC and my Anthem I found my subwoofer levels were a bit too high. I was told the ARC was right and that I shouldn't change a thing. Well after I ran Audyssey my sub sounds as powerful and smooth as I preferred from my 3808. So far I prefer Audyssey.
post #5250 of 7861
+1
Using the XPA 3 too with my 4520...
