Hi and thx again for the tips. I was away thats why I couldnt write sooner.
I did use toslink and I got the sound from the TV so thanks
I was expecting to have the sound by using only Hdmi but apparently I was wrong
Thats not good that via airplay you can play only audio not video
hope they can add videoes to airplay streaming to denon aswell.All now working well with my Denon 4520 and I love the sound and picture quality
I am trying to use the denon remote controll to control my Tv and ps3 and Cbl. Sofar only the Tv has been with success.
I am ordering an Oppo very soon. Which model you guys think I should choose from Oppo BDP-103 and 105? And how should I connect it to Denon in order to get the best quality?
Glad that the Toslink solved the audio issue! As far as Airplay being audio only, that is just the way it is. I believe I mentioned earlier, Apple TV is a reasonanbly-priced option you might want to consider.
The Oppo 105 has the enhanced analog audio, I believe. To take full advantage of this superior audio interface, one of your connections would need to be analog stereo, with no analog-to-digital conversion in the signal path, i.e. no Audyssey room correction, no bass management, etc. If you value playing music in stereo with a good set of speakers set to "Large", then the 105 may be worth the price difference for you.
Having said that, my BDP-93 playing through the HDMI connection, using full Audyssey room correction, DEQ, etc. sounds superb. For me, the enhanced audio curcuitry of the BDP-95 (and now the 105) was not a good value.
old age does that to you...
you could literally watch stuff come up one letter at a time on the screen... but if i was, umm, not functional enough to drive, it worked well enough...
