Featured Stories
Topics Discussed
Related Forum Threads
- When do the 2013 Denon's come out? Any new features we should expect? Last post on 2/5/13 at 3:39pm in Receivers, Amps, and Processors
- Denon 4520ci remote control RC-1165 Last post on 4/10/13 at 4:04pm in Receivers, Amps, and Processors
- Denon vs Yamaha reliability Last post on 4/4/13 at 7:34am in Receivers, Amps, and Processors
- Tiny Tribute Theater Last post on 5/16/13 at 12:36pm in Dedicated Theater Design & Construction
- Japanese vs. English vs. American - Building a 5.1 Chanel Surround Sound System - Which Receiver... Last post on 3/25/13 at 6:02am in Receivers, Amps, and Processors
Related Reviews
The **OFFICIAL** DENON AVR-4520CI thread - Page 32
Gear mentioned in this thread:
- jdsmoothie
- Trader Feedback: 0
- AVS Addicted Member
- offline
- 34,458 Posts. Joined 9/2007
- Select All Posts By This User
So I got my 4520 thru today from AVS (thanks again Mike!), but i'm noticing something odd which I hope isn't a problem with the amp, rather something i've done or setup wrong.
I've got the 4520 all setup now for 11.1 (9.1 with the front highs pre-out'd to another power amp), ran thru all of the Aud. cailbration, and all the input setup done thru the GUI nice and smoothly.
I've put most of the inputs to NEO:X to use the 11 channels - in case that is a cause of the problem.
But the volume level seems really low out of the amp - significantly lower than my old 3806 was! Watching Cable TV from my Tivo I have to have the volume up at 50+ for a comfortable listening level - and I'm not one for needing a crazy high volume level.
When I tried to push the new setup with some blu-rays (or airplay or any input), to see how the 11 channels sound , I was having to push the volume past 65 to get any real volume, and then the amp started to shut itself off - the power light starts flashing red, and until it goes back to a solid red light I cannot turn it back on again,
Anyone got an idea on this issue, or am I going to be needing to get an RMA number and send the unit back?
-David
Unlike on your 3806, on the newer model Denon AVRs , reference volume (ie. 85db+) is set to a master volume of 0db (relative)/80 (absolute) when Audyssey Dyn EQ is enabled. The AVR master volume will have to be raised above -50db/50 for any appreciable volume with normal TV viewing being about -35db to -25db/45 to 55 and normal movie/music listening about -25db to -15db/55 to 65. The AVR should be able to go to at least 0db/80 without shutting down so check for loose speaker wire strands from one post touching another post as that is the most common reason for shutting down at higher volumes.
- jdsmoothie
- offline
Center ----> Setup - Audio - Dialogue Enhancer (p. 121 OM)
Sub ----> Setup - Audio - Subwoofer Level (p. 121 OM)
Edited by davidbarrickman - 11/15/12 at 3:12am
- jdsmoothie
- offline
- kaphely
- AV enthusiast
- offline
- 38 Posts. Joined 11/2012
- kdp99
- offline
- 69 Posts. Joined 3/2001
Noticed a lot of dicussion about remotes and using codes from other Denons with the 4520. I have a pronto ccf and associated spread sheets with the full Denon code set for the 5803, a lot of which work with my 5800 and should work with the 4520 for things like channel level adjustment etc
I also have these imported into a URC MX950 file, form which they can be grabbed and copied into most other URC remotes. PM me if you want them, or if anybody has a share site you can have them to upload ot it.
Keith
- batpig
- terrorist and rioter
- online
- 21,209 Posts. Joined 2/2007
The loss of a channel level button on the 4520 is unfortunate, I sometimes like to make small adjustments "on the fly" without having to go into the menu/test tones...forgive me if this has been asked before, but if you point a 4311 or 4x10 remote at the 4520 and press the CH level button, does the old GUI still come up? Is there any other workaround? Thanks.
The CH LEVEL button no longer works on the new models. If you want to tweak levels you can add the individual speaker volume discretely to your programmable universal remote. If you missed it go back and look for posts by "kaphely" where he talked about the process. This post on my website is a good starting point: http://batpigworld.com/wp/?p=106
- mtbdudex
- Mike R, P.E.
- offline
- 2,982 Posts. Joined 5/2007
Is this Denon speak for anamorphic mode?
I have an panamorph UH380 a-lens, and use my sony VW60 anamorphic mode to stretch up/down - the lens stretchs width, will this be same?
If so, that opens up other PJ's for scope usage w/o needing an extrrnal video processor.
copy/paste from the manual:
Sets whether video signals
are vertically stretched or
not.
On : Stretches video signals vertically.
Off : Does not stretch video signals vertically.
“Vertical Stretch” can be set when “i/p Scaler” is set to anything
other than “Off”.
My sony VW60 below
If you have an OPPO BR, it also does the vertical stretch. I was using the vw95 to stretch the image for my U380 also, but when I had it calibrated the calibrator noted that the sony would lose some sharpness in it's stretched mode compared to normal viewing. The OPPO's vert stretch didn't change sharpness/resolution from the 95's non stretched image. Bear in mind, this required close screen inspection with a test pattern, I don't think I could notice it on video material.
- flint350
- Trader Feedback: +1
- offline
- 2,095 Posts. Joined 11/2002
Thanks jd. I remember reading some posts earlier in the thread by 4520 owners who were able to access some things not on the 4520 remote/menus/front panel by either programming 4311 codes into a universal and/or just using the old remote(s). Just wondering if anyone had tried this and maybe the old channel level GUI might appear...
I still have my 4806 which had that feature, so I tried it on the 4520 - no joy. You can, as others have said, use a programmable remote like the URC to do it though.
- flint350
- offline
I'm looking at page 130 of the user manual, vertical stretch.
My Oppo BD-93 and my Projector both offer the anamorphic stretch and those are what I generally use with my A-lens. I did, however, try the Denon vertical stretch and, for some reason, could not get it to work. I didn't really dig deeply into why as I already have a viable method in place, but remain puzzled about it. I also noticed that my Denon OSD disappeared when I turned off Video Conversion. Two video anomalies that I have to investigate further when I get around to it.
>> I would also suggest changing the volume display from "absolute" (0-99) to "relative"
>> (-80dB - 18 dB) in the 4520's option menu. (absolute is the new default, used to be the other way around...) Report back with your channel level info and at what master volume your AVR is going into protect mode ( -10 dB?0 dB? 5 dB? -20 dB?)
>> it's going into shutdown somewhere around -11dB to -8 dB
I ran Audyssey yes, the channel level info is :-
FR L -5.5dB
FR R -5.5db
C -3.5db
Sub 1 -5.0dB
Sur L 0dB
Sur R +12dB
Sur Back L -1.5db
Sur Back R -2.0dB
F Hi L -0.5dB
F Hi R -1.0dB
F Wide L 0.5dB
F Wide R -0.5dB
>> Try running Audyssey once more, an odd mic position in a null spot might put the readings off. Cheers.
i'll retry the Audyssey run right now - the surround R number seems really odd!
>> Unlike on your 3806, on the newer model Denon AVRs , reference volume (ie. 85db+) is set to a master volume of 0db (relative)/80 (absolute) when Audyssey Dyn EQ is enabled. The AVR master volume will have to be raised above -50db/50 for any appreciable volume with >> normal TV viewing being about -35db to -25db/45 to 55 and normal movie/music listening about -25db to -15db/55 to 65. The AVR should be able to go to at least 0db/80 without shutting down so check for loose speaker wire strands from one post touching another post as that is >> the most common reason for shutting down at higher volumes.
Yeah -50dB on the TV input has a really low (just audible) volume, -35dB is 'normal' TV volume. It's definitely quieter than my old 3806 was, which is kind of funny. Time to get that xpa-3 for the front channels I guess!
so taking the +12dB on the Aud report as an odditiy, I checked the cabling into that speaker, and it was a little frayed, so I stripped it back and reconnected it all up. That fixed the shutdown issue - can take the volume all the way up now with my problems if I want to!
The only odd thing I have seen is that I thought i'd re-run Audyssey again now the cable was fixed (rather than just manually turning the level of that one speaker down to a more sensible level), but every time I run it I get 2 or more speaker now reporting being out of phase - none of which reported out of phase in the past. All the wiring is in phase, i've checked and double checked. Oddly it's different speakers reporting being out of phase on most runs of the Audyssey run - one or 2 consistently, but a few variable depending on the run?
thanks everyone for the things to try out.
-David
- AustinJerry
- offline
- 3,347 Posts. Joined 1/2003
>> In addition to source level, check channel levels...did you run Audyssey? If so, where does Audyssey have the channel levels set at?
FR L -5.5dB
FR R -5.5db
C -3.5db
Sub 1 -5.0dB
Sur L 0dB
Sur R +12dB
Sur Back L -1.5db
Sur Back R -2.0dB
F Hi L -0.5dB
F Hi R -1.0dB
F Wide L 0.5dB
F Wide R -0.5dB
-David
"Surround left = 0, surround right = +12" looks peculiar, and could indicate something is wrong. Can this be explained?
- Selden Ball
- offline
- 4,387 Posts. Joined 1/2001
You may have overlooked that papa_laz fixed the +12 by redoing the connections on that speaker's cable. (+12 indicates that the speaker is too quiet and Audyssey had to turn its gain up to max to hear anything.)
papa_laz,
If you know the phasing is correct, you should be able to select "continue" to proceed with the calibration. I seem to recall that some people believe that Audyssey reports a phase problem when it gets confused by reflections. You might want to consider some physical room treatments.
- AustinJerry
- offline
I am upgrading from the Denon 3802.
First, as I have stated in prior posts, I have it hooked up to my Pioneer Elite via component output, given that there is no HDMI.
Contrary to what I understood from replies on the thread all menus and setupscreens are clearly visable on my TV via component outputs.
Ipod.Ipade menus and network menus as well as pandora and spotivy menus and album covers were clearly visable.
1) My first question is about Spotify. I am using the 30 day trial, but I cannot seem to find a list of, or a way to play radiostations on Spotify on the Denon, although it is easy to do from my Iphone or Ipad.
Search results within spotify are also not very helpful, giving many names listed without much way to tell one song from another. It is much easier to find a song on the ipad, then save it to a folder and then open the file on the Denon then to play it.
2) Started programming my Logitach Harmony One, and I read somewhere either here, or on a link from here, that the Power toggle should be learned from the factory remote so that it does not turn all zones on, like the Harmony seems to do.
Is there a discrete ON that does NOT turn on all zones (and if not, does it really make much difference if nothing is hooked to the other zones, or does it use more power anyway?)
3) and my last question tonight, is regarding headphone out. I prior used a digital out (optical or coaxial), from my Denon 3802 to my wireless Pioneer headphone base unit, which worked great. Someone on this thread suggested I use Zone 2 analog out instead. The headphones have dolbey digital which I guess will not work with analog out, but a guess a fair workaround if I could just get the analog to work.
My audio inputs to the receiver are all digital, and I would hope the receiver would convert this to zone 2 analog outputs, but I seem to get no sound output to the headphones. Any thoughts?
Overall, otherwise, I seem to really like the reciever so for.
Thanks in advance for your thoughts/answers.
Edited by Tachy - 11/15/12 at 9:16pm
- jdsmoothie
- offline
-David
Try setting Dynamic Volume to OFF. ( Audio / Audyssey / Dynamic Volume )
- ccotenj
- Trader Feedback: +30
- offline
- 21,915 Posts. Joined 3/2005
and the thanksgiving present is on its way...
who out there is using zone 4 out? if anyone, what kind of behaviour are you getting if you try to send the same source to zone 1 and 4 and the sinks differ in capabilities? does it merely send lowest common denominator (hoped for), or not work at all?
- AustinJerry
- offline
The reason you don't want to power on all zones is that InstaPreview will not work if zone 4 is active. If you don't want to use InstaPreview, then it may not make a difference to you. When you are learning the command for the Harmony, make sure the Denon remote is set to the Main Zone, and then learn the Power On key.
- AustinJerry
- offline
- ccotenj
- offline
i no doubt will have some...
quick q on that... did you place it close to the avr or close to the display? with any of the boxes i introduced into the chain after the video left the 4311 (lumagen, 3dbee, splitter), it didn't seem to matter.. so far on the 4520, i'm only using the lumagen, and it's close to the avr, but will be moved close to the pj soon...
some things i thought of for people to do when we get bored...
if anyone else has gone from a 4311 to a 4520, it'd be interesting (well, to me, anyway) to do some experimentation here to see if the hdmi output signal strength has been bumped up... in the 4311 thread, occasionally users would post issues that indicated the hdmi output signal strength could have been better (i didn't experience this, as alluded to above)...
another thing that would be interesting to see is if people who had issues with bandwidth piggy things like deep color passing through the 4311 (although there's no real good reason to use it, unless you have a true deep color source) still have the issue with the 4520...
- AustinJerry
- offline
^ Hey Chris,
I placed the Darblet close to the display (3" HDMI cable), with a 20" HDMI cable to the 4520. I didn't try both, but the Darblet form factor and appearance didn't fit well with my equipment rack. BTW, I'm sure you have read on the Darblet thread, some have used IR extenders so that the Darblet can be placed completely out of sight. I tried this, but for some reason, the extender didn't work well for me. YMMV
I can't comment on the other 4311-to-4520 conversion topics, since I never have had HDMI issues with either AVR.
I have it set up in a 7.1 configuration with front wides instead of surround back and bi-amping the front channels.
Took me a little while to figure out the amp assignments
Overall I'm very pleased with this receiver, and have had no issues. Sound is similar to my 4310.
I really like the different sound modes.
Played with the dialogue enhancer a little bit, but I find I don't need it with my set up.
Do most of you use Dynamic Volume? I use the Dynamic EQ, but tend to leave Dyn Vol off.
I like the ethernet switch, which allows me to ditch my stand-alone switch.
Missing the blue DSX light like many others. Miss the simultaneous input & output channel display on the front.
REALLY miss the AC outlets on the back that my 4310 has.
- mtbdudex
- Mike R, P.E.
- offline
Just took the plunge on a 4520, upgrading from a 4310.
I use AC outlets on the back of my 4308 to power the IR>BT adapter so I can power up my P3 with a Harmony remote, now I'll have to find another open plug for that.....
I also like the simultaneous input & output channel display on the 4308 front, tells me what's going on audio wise, can live without it but questions why on a top tier AVR did Denon remove it?
I am going to try a smart switch power strip and see if that works.
Re: the front display I have no idea why they would change a long-standing denon tradition and useful feature of displaying both input and output channels.
- mtbdudex
- Mike R, P.E.
- offline
penny wise but pound foolish?
I truly hate these cost savings measures, not in their higher end AVR's......unless they are using common circuits with their lower end AVR's and that drove the change.....
- The **OFFICIAL** DENON AVR-4520CI thread
Recent Discussions
- › Onkyo TX-NR1010 1 second ago
- › indirect lighting in crown molding 25 seconds ago
- › The Official Stewart Film Screen thread. 33 seconds ago
- › Dune D1 hardware and skin questions 49 seconds ago
- › Blu-ray that does the best job of upscaling regular DVDs 1 minute ago
- › Did anyone try the new Xpand 105s with horizontal polarization for... 1 minute ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 1 minute ago
- › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ 2 minutes ago
- › Emotiva amp connected to my Yamaha AVR, would this help any? 2 minutes ago
- › Official Panasonic S60 Series Discussion Thread 2 minutes ago
Recent Reviews
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
