AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** DENON AVR-4520CI thread
The **OFFICIAL** DENON AVR-4520CI thread - Page 34
post #991 of 4879
Originally Posted by VTGOLFER View Post
Or you buy an AppleTV and stream from that to your AVR.
I would for an inexpensive alternative the Apple TV works great and sounds great streaming music in AIFF or ALAC with no glitches. It streams HD movies well as well. Hopefully one day it will be able to stream movies with the new audio codecs.
Great product.
Here you go
http://maclegion.com/software.htm?app=beamer
Play any movie from your Mac on Apple TV
Beamer is the AirPlay Video Player for Mac. It supports many movie and subtitle formats, so you don't have to convert your videos to an Apple TV compatible format. Simply drag-and-drop a movie on Beamer and it will start playing on your Apple TV!
Unlike Screen Mirroring, Beamer is specifically optimized for video playback at the highest quality. What's more, you can pause, forward and rewind using the Apple TV remote. No need to get up from the couch.
All common movie formats (AVI, MP4, MKV, etc.), codecs and resolutions up to 1080p are supported. Non-h.264 video is transcoded on the fly. Subtitles are supported, both embedded subtitle tracks and external subtitle files. Supported formats are SSA/ASS, SubRip/SRT, SubViewer and MicroDVD.
post #992 of 4879
Sweet thanks for this
post #993 of 4879
I added the discreet codes to my URC remote to scroll the input sources. Network comes up but
I do not see "Network" in the menu to hide sources. There is no high speed internet where the
4520 is located.
Is there any way to delete network?
post #994 of 4879
Originally Posted by Tachy View Post
Curious if anyone has tried the new firmware update that came out today, and if anyone knows what it fixes?
Since I have two cases open with Denon support on the 4520, I called and asked if there are any release notes on this firmware version.  The answer I received:  information on firmware updates are not made available to customers.  I asked if there had been any progress on my two cases.  Answer: no.
JD, do you have any insight regarding the changes in this FW upgrade?
post #995 of 4879
Longest firmware update I've ever done. 45 min. I'm hoping it clears up the HDMI issues I've been experiencing.
post #996 of 4879
Nope, didn't fix my issues.
post #997 of 4879
can you refresh my memory as to your hdmi issues? maybe "we" can help... smile.gif
post #998 of 4879
I've been on the phone with Denon all morning. Looks like it might be a hardware issue. After 3 days of perfect use, my screen started glitching and having handshake issues. It was turning rainbow colors and pixelated. I've tried different HDMI cables, and even a different TV with a shorter cable (as opposed to the 35' cable I had to my projector). They're ready for me to send it in to repair.
post #999 of 4879
Anyone know if the Marantz PM8004 would be a good addition for the 2 channels to expand to 11.2 from 9.2?
Problem is it's only rated at 70W (8 ohms), 100W (4 ohms).
I think it says you can run it in straight "power amp" mode. I'm guessing that disables the volume control and preamp features??
I'm asking because a local retail store is clearancing these guys at $400 appiece .. .
http://us.marantz.com/us/Products/Pages/ProductDetails.aspx?CatId=HiFiComponents&SubCatId=0&ProductId=PM8004
post #1000 of 4879
On the AVR4311, the current firmware component versions could be displayed by pressing and holding the Status and Return buttons when powering on the AVR. Is there similar functionality on the 4520 (other than the Info area in the Menu)?
post #1001 of 4879
The firmware update did not effect the Pandora or Spotify issues.
post #1002 of 4879
Firmware Update Warning
I just completed updating the 4520 firmware to version 3325-0792-1424.  As per the update estimate, it indeed took approximately 46 minutes to complete.
While I know from experience that a FW update is not supposed to affect the AVR configuration or its Audyssey calibration, being overly cautious, I checked the settings anyway.  Much to my surprise, the AVR calibration settings (e.g. distances and trims) had reverted to the previous calibration values.  Anyone who upgraded from the AVR-4311, or has followed the 4311 thread, will be familiar with a peculiar behavior in which the 4311 reverts to prior calibration settings after a power interruption.  Evidently, this behavior can happen after a firmware upgrade as well, which could have a bad impact on an unsuspecting owner.
I always save the AVR's configuration after a calibration, so it was a simple process to restore the calibration settings from the most recent save.  My advice to all 4520 owners is to take the following steps when you upgrade the firmware:
- Make sure you have a successful configuration save file (make sure it isn't all zeros). The save process is documented here.
- Jot down (or take a screen shot) of your settings.  Go to \Speakers\Audyssey\Check Results.
- Conduct the FW upgrade.
- Immediately after it has finished, check the settings.
- If they haven't changed, you are OK.  If they have changed, restore the settings from the Save file you created in the first step.
If anyone else observes that settings have reverted to previous values during the FW upgrade, please post a comment in this thread so we can determine if this is an isolated case, or a repeatable bug.
post #1003 of 4879
Will do when I get home Jerry. I'll post later tonight
post #1004 of 4879
Yup. Post #4 updated.
post #1005 of 4879
Setup was very simple. Denon has put a major effort to make the 4520 more user-friendly and this is evident with the way it hand-holds you through the setup process. The only problem with the setup was that the audio sounded horrible and sure enough, Audyssey Dynamic Volume had been set on by default and that resulted in a very muffled sound. Somehow, the subwoofer level was at -10 and that extinguished the bass so I pushed that to zero. I'm not sure if Dialog Enhancer was on and I switched that off too. After these adjustments, the sound was good. For video, I only have a pass thru so it was not a problem.
I like the remote and the menu better than the previous models (4311, 4810, 3808). It is friendlier and easier to navigate.
Since the unit is only on loan, I haven't purchase the Audyssey Pro license yet so immediately, you can detect an audio difference, particularly in the target curve. I have a large room so I use the Pro target curve with a steeper high frequency roll-off. Without this, there is a lot more sibilant sounds. There are other audio differences because of Pro but that's not relevant to this thread.
Mark
post #1006 of 4879
Before even considering Audyssey Pro, you really should read the Audyssey 101/FAQ guide linked in my sig to ensure you have properly used the Audyssey setup procedure. Dyn Volume was set to ON as you set it that way during the setup process.
post #1007 of 4879
Well thanks for posting that! I hesitated to do a save prior to do the update but because of your post I decided to save my settings first. Good thing I did because my receiver was also set to previous settings after the update as it did with yours. So I can confirm it is not isolated but reproducible.
I checked the change log in post #4. First, where do you get this info jdsmoothie? Do you work for Denon? Anyway, it is good that a guy like you give us this info!
I expected more from this update though, first I would have thought they would fix the Save issue where you can't save unless your network is set to off in standby. I also reported a couple of Web GUI bugs to Denon that would have been easily fixable, likethe fact that the web GUI reports my sub distance as 1/10 of what the GUI on TV does and the fact that some options are available and should not be like two channel speaker setup when I already use all amps for surround. This is grayed out on the TV GUI. Anyway as a first time Network AVR user, can I expect these to be fixed? Or will Denon ignore what I reported?
So thanks again for saving me a lot of trouble AustinJerry!
Edited by kaphely - 11/20/12 at 4:00am
post #1008 of 4879
As a clarification, I've had an Audyssey Pro kit for more than 3 years now and I've used it progressively with a Denon 3808, then 4810 and finally a 4311. I've also been following the Audyssey thread daily for the last 6 years so I'm pretty familiar with the FAQ/Setup Guide of Keith and Giomania. smile.gif
The problem is that for each new AVR, you need to buy a license for $150 and if I'm not going to keep the 4520, I'm not spending that money.
I'm not fully certain but I really don't think that Dynamic Volume is set on or off during the setup process. It's the default setting after the setup.
Mark
Edited by streetsmart88 - 11/19/12 at 5:21pm
post #1009 of 4879
I would say send it in
or better yet....get a replacement unit from the dealer you bought it from
Somehow....in my experience these issues dont get better and can be very frustrating
A few years ago I had a 4308...Spent all kinds of crazy time on the phone with Denon support
Their attitude was that it was something I was doing incorrectly...??
Anyway...finally I sent it in for repair to Panurgy
Got it back 3 weeks later..and the problem was still there
After a "lovely" conversation with their tech support... Denon decided they could figure out a way for me to give them the unit back for a 100% refund
Warren
post #1010 of 4879
I did a little "write up" on the 4520...
http://hstrial-jrodriguez996.homestead.com/DENON-AVR-4520CI-RECEIVER-REVIEW.html?_=1353372722253
post #1011 of 4879
Tks joe. Reading now!
post #1012 of 4879
When I was using a 4311, I was used to being to establish custom settings for 2-channel playback.  On the 4520, when I go into Speakers\Manual Setup, the 2ch Playback option is grayed out.  When does this option become configurable?
post #1013 of 4879
AFAIK, the "2CH Playback" settings (p. 145 OM) should always be available. Try setting AMP ASSIGN to "9.1CH/2CH Front".
post #1014 of 4879
Mark
My point was that you say you "pushed the 'sub' volume to zero" which I took to mean you adjusted the level with the remote rather than reducing the gain on the sub and running Audyssey again.
post #1015 of 4879
I'll be glad to try this temporarily, but I have a 11.1 setup. IIRC, on the 4311, the custom 2CH settings were invoked anytime I selected stereo output, regardless of the amp assign configuration.
post #1016 of 4879
Don't know if I am one whom you trust wink.gif, but I am using the Darblet with the 4520. I recommend it highly. Maybe you need a Thanksgiving Day present?
I was using the Darblet too and it is indeed nice. I had to send it back though since it was causing me some HDCP issues. =( While noticeable, I wouldn't say it was earth-shattering in my setup so not a huge loss.
who out there is using zone 4 out? if anyone, what kind of behaviour are you getting if you try to send the same source to zone 1 and 4 and the sinks differ in capabilities? does it merely send lowest common denominator (hoped for), or not work at all?
I FINALLY have my 4520...and I'll probably be using the Zone 4. I'm going to try a few crazy ideas with it and see how it goes.
post #1017 of 4879
post #1018 of 4879
Originally Posted by joerod View Post
Joe, I want to make sure your situation was similar to mine. Had you actually done more than one calibration on the 4520? If no, then there wouldn't be a previous calibration to revert to. If yes, were the differences between the two calibration settings such that it would be obvious that the settings reverted? For example, the distance setting for my mains with the previous calibration was 9.9', and the current calibration has the distance as 10.0', so I immediately noticed a difference. Just checking...
post #1019 of 4879
Makes perfect sense. I only did one calibration. I was worried I might lose settings but even if I did I would just pull out the mic again. smile.gif
post #1020 of 4879
Joe, I've read your review and you mentioned that the Onkyo and Denon sound different, but didn't elaborate in what way. Can you please expand on how they differ sonically? Also what makes the XT32 better on the Denon?
