AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs ›  Paterson USB TV Translator to use the serial port on Replay TV to the USB port on the DirecTV receiver
Paterson USB TV Translator to use the serial port on Replay TV to the USB port on the DirecTV...
post #1 of 16
I use my Replay TV with DirecTV ...
DirecTV told me my 1996 model RCA DirecTV receiver was going to become obsolete and they would swap me a new one for no charge & no contract
I received the new receiver and ... none of the Replay TV IR blaster codes work with the DirecTV D-12 -100 receiver ...
I tried to google a solution and ran across a Paterson USB TV Translator to use the serial port on Replay TV to the USB port on the DirecTV receiver
http://www.patersontech.com/products/
When I tried to order it - it's been discontinued: http://www.patersontech.com/ ...
Has anyone run into this previously? ... Anyone know where I might find a used Paterson USB TV Translator? ... or, alternate TV translator?
post #2 of 16
I moved on to SageTV, but faced the same problem with DirecTV. The solution is to get a standard USB to serial connector cable available for about $15 most places, AND THEN get a "null modem" serial adapter to connect between the replay and serial cable. The null modem just reverses the in/out orientation of the serial connection.
post #3 of 16
Hey!
thank you very much for your expertise and the quick response ... I searched for your
solution and came up with this ... do you think it will work?
http://www.walmart.com/ip/StarTech-ICUSB232FTN-Startech-1-Port-USB-to-Null-Modem-RS232-DB9-Serial-DCE-Adapter-Cable-with-FTDI/21097418
are the operating systemn requirements of the cable compatible with the Directv D-12 receiver / Replay TV HS 2000 connection scenario?
post #4 of 16
The USB port on the ReplayTV is inactive.
I beleive all ReplayTV units *do* have a db-9 serial port that can control a set top box. Not sure if it can talk to the DirectTV box though.
Robert
post #5 of 16
thanks for the response ...
the Replay TV has a 9 pin serial port ... the DirecTV receiver has a USB port ...
they must be able to commubicate because Paterson sold 5,000 of the USB TV Translators ...
post #6 of 16
I would suspect that the Walmart adapter may work, but have never used that item.
I got my info here:
http://forums.sagetv.com/forums/showthread.php?p=355536&highlight=serial+control#post355536
the link includes tested adapters from monoprice.com
I'm controlling a DirecTV D12 from my computer's serial port (like replay) with this setup, and note, no drivers required.
post #7 of 16
Hi New Yankee -
just received the parts from monoprice ...
USB-to-serial adapter (1 @ $6.34 ea)
db9 F/F Null Modem (1 @ $1.19 ea)
hooked my Replay TV DVR and DirecTV D-12 receiver together ...
nothing ...
do you think something evil is going on at DirecTV?
thank you again for sharing your knowledge and responding ...
post #8 of 16
Did you check your settings to make sure you are communicating with the serial port and not IR? Just a guess!
post #9 of 16
nothing ...
Did you upgrade your RTV IR Blaster codes to add the D-12 capability? There were replies to you on PlanetReplay from srfrdan and hdonzis detailing getting the RTV to work with the serial to USB cable, did you read them?
post #10 of 16
without the translater u have to install the codes and they work for the d-12. im using a translater on the d-12 cause i could get one. i also just hooked up a r-15 using the replay updated to the ir codes because its old tuner broke and u cant get the translate nowr. i also have an h20-3h21s and the d12 all have the same remote. want to buy a remote ----biggrin.gif--d
post #11 of 16
yes ... I changed the Repaly TV setup to serial before I installed the null moden and adapter
post #12 of 16
no I did not ... thank you for the direction
post #13 of 16
post #14 of 16
post #15 of 16
I too am interested in purchasing more of these. I ordered one some time back, and should have ordered more... mad.gif
post #16 of 16
If anyone finds a source for the serial-to-USB translator, please advise. I would also like to purchase at least one of them.
  Back to Forum: ReplayTV & Showstopper PVRs
