AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › panasonic ut50 default white balance value
post #1 of 5
I Mest up the wrong white balance setting in the service menu of my ut50 can someone tells me the default value for default normal and warm please
post #2 of 5
From the service manual:
WB-ADJ
R-CUT 80
G-CUT 80
B-CUT 80
R-DRV DF
G-DRV FF
B-DRV 7C
ALL-CUT 80
ALL-DRV FF
service manual download:
http://elektrotanya.com/panasonic_tc-p55ut50_ch_gpf15du.pdf/download.html
http://elektrotanya.com/?q=showresult
post #3 of 5
Go to this thread:
http://www.avsforum.com/t/1412033/the-official-panasonic-ut50-settings-issues-thread
post #4 of 5
Thanks a lot
post #5 of 5
WB-ADJ
R-CUT 80
G-CUT 80
B-CUT 80
R-DRV DF
G-DRV FF
B-DRV 7C
ALL-CUT 80
ALL-DRV FF
The white balance setting are different from set to set, put on a 480i or 480p source and check the SD color space those should match what you had in HD.
