Just finished Warren Peterson's book and a little overwhelmed! (to say the least) Thanks to our cats destroying the carpet in our TV room (you don't want the details) I now get a Home Theater!! (I guess I can't be too mad at them -
The room will be split off with a new wall giving me 19 x 15.5 x 8.5 ft space - so not huge. (The wife gets a lounge area in exchange for Theater)
The first design I was going with looked good but the screen wall was the new wall and also had the door (which I understand is a bad idea). Two other walls are outside walls and the opposite wall to the new one is essentially a rock wall with a large inlaid rock base on the floor. (Currently has wood burning stove and vent to rock wall which is actually part of fireplace.
Here is my first idea:
And the current:
What I was thinking was create another new wall in front of the rock feature and treat it like a concrete wall - attach the new wall with RSIC clips. Then build a stage & proscenium for the screen.
Problems:
1) What do I do with the rock floor?? I guess I can try to remove b/c if I try to cover with the stage - that's a bit big. (It's 64 in long)
2) Do I put insulation between the rock wall & new wall?
3) Could I make the new wall a screen wall?
Thanks for any help in advance !!
Jeff
Edited by jefftr - 9/19/12 at 9:42am
)The room will be split off with a new wall giving me 19 x 15.5 x 8.5 ft space - so not huge. (The wife gets a lounge area in exchange for Theater)
And the current:
Problems:
Jeff
I'm assuming Lowe's is just as far. That would not have worked for my build. I'm there several times a week, sometimes multiple times in the same day. I guess you really have to plan ahead.
