Calling HK 7550HD owners...
I was wondering if you have 3D working in bypass mode via a HTPC.
I have brought my Amp in to do the 1.4 upgrade twice and still cannot get it to work.
The 2nd time was to make sure it had taken the upgrade so they redid it.
I'm using a HD5770 card, with an EDID override, and I recently bought a HD7750 card and it did not work too!!!
I'm asking if yours works can you please tell me what video card you are using?
Many thanks in advance.
Another problem I am having is with the 2nd sub output.
It NEVER comes on! I have to change inputs to get it to work.
A major problem I am having is it will not hold it's settings.
Let me explain.
I have the .1 connected to my front 2x 15" subs
I have the .2 connected to my rear 2x 15" subs.
I tune the .1 one to my fronts with the distance control and a 80HZ sine wave till I get the loudest sound.
I do the exact same thing for the .2 sub out.
(This is a great way to tune in your speakers with the subs)
Once calibrated the bass is phenomenal!!!!
The problem is once I turn the unit off and then back on the settings remain the same but the bass is all screwed up and I must do it all over again.
It seems it will not hold it's settings.
Do any of you experience this?
Let me explain.
