AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › RCA male to speaker wire?
post #1 of 2
I have a sub woofer that takes speaker wire & a receiver that only outputs sub as a RCA..
What are my options??
post #2 of 2
Unless there is an amp with your sub, you're going to have issues.
If you have a passive sub, you could: buy a separate amplifier, or build a crossover (or at least Low pass filter) and try hooking the sub up to speaker b posts on your receiver and running both (although this could/would put a lot of strain on yur receivers amps).
