Originally Posted by rukus29
it is purely an effect of how you set the three controls in combination. straight from a JVC engineer who was helping me and Mike determine if there was something wrong with my PJ (turns out i dont think there is, just most of the effects are due to software enhancements rather than actually eshifting the image): "The 4K Profile choices are simply preset combinations of Enchance/Dynamic Contrast/Smoothing settings."
so if one profile seems soft to you, it just means you prefer a different combination of the 3 mpc controls. play around with them.
Originally Posted by SOWK
rukus29... That is just not true.
Set all to 50,50,50 and switch between them. There are drastic differences.
Also anyone that is getting e-shift for the first time... You must turn off e-shift while checking convergence and focus. E-shift up close looks very blurry, and you will think there is something wrong with your projector.
If those are the 3 different (types) adjustments in the mpc. When you have all 'modes' set at the default 50/50/50. Then go from each mode (film, high resolutions, hd, etc.) back and forth, I see the difference between each one... So does that mean, that even though there all set at 50/50/50, there actually at other numbers preset in each 'mode' (to begin with).
Then in each 'mode' you can adjust the 3 different types (enhance/contrast/smoothing) to your liking...
Does anyone have experimented settings that they think are the sweet spot (for them...). That I can try like as if it was another default. Example the 35/20/20 & what mode (that someone else had).
Thanks, eh.
Thanks, eh.
