Do you use different color difference formulas?Originally Posted by Schwa
Here's my calibration report...as you can see, green is under 3. In my case it did take some farting around with the two effective green controls because adjusting brightness would affect hue and saturation and adjusting hue would affect brightness and saturation. Adjusting saturation, in my case, did nothing.
I used the Natural color mode and Standard color profile.
CP use CIE94 while CM seems to use dE2000, Different color difference formula will result in different dE.
Btw, I run i1d3pro profiled against i1 pro and they were calibrated by the manufacturer a year ago. I don't think it has no such huge errors.
Edited by freebits - 1/20/13 at 5:40pm
In that case, I might just hang with my straight 2.22 for now and not even mess with tweaking it, but next time I run an auto cal use a seperate CMS setting in the Lumagen with the tweaked gamma/greyscale so I can have both my original untweaked and my new tweaked and experiment with both depending on the material.
