This is a cut/paste from my topic on the AMD forums. I'm sure you guys are much more knowledgeable than the regular users over there. I have bolded the main issues I am having. I would GREATLY appreciate any help!!!!!!!!!!!!!!!!
Graphics Card
-ATI Radeon 2100
AMD Catalyst Driver Version, and Driver History
-12.6 released 7-24-2012
Operating System
-Fresh install on formatted HDD of Windows 7 64 bit all current available updates
Issue Details
-Only my processor shows up in AMD VISION and I have no option to adjust the display
-I use my HTPC connected to a projector and have a thick black border around the image instead of filling the screen. in the past (in Vista) I had to use Catalyst Control Center to get the image to fill the screen.
-I also installed the Ceton Infinitv 4 cable card tuner and in the "Digital Cable Ready" test, my system fails due to not have hardware acceleration enabled.
Motherboard or System Make & Model
-Gigabyte GA-MA74GM-S2 with original BIOS - needs to be updated I'm sure
Power Supply
-Antec Earthwatts 500 watt PSU
Display Device(s) and Connection(s) Used
- Epson 6100
-DVI to HDMI to the receiver and HDMI from the receiver to the projector
Applications and Games
- Windows home screen and Windows Media Center
CPU Details
- AMD 4850e
- no overclocking
Motherboard BIOS Version
-Not sure. I can look when I get home.
System Memory Type & Amount
-2 gigs of something. Can't remember what brand. Not the issue.
Additional Hardware
-Sata II 80 GB boot, IDE 400 GB data, LG DVD burner, Ceton InfiniTV 4
Additional Details
-I can't access the Catalyst Control Center though I think the AMD Vision has replaced this. In AMD Vision, I can access the CPU but there is no display adapter (2100) to select.
Graphics Card
-ATI Radeon 2100
Operating System
Issue Details
Power Supply
- Epson 6100
CPU Details
- AMD 4850e
- no overclocking
Additional Hardware
Additional Details
