We have a PRO-620HD that worked flawlessly for ten years. Then a few weeks ago we were watching it and heard a "click" and the screen went black. The red standby light was the only thing lit. We turned off the set at the power button in front and waited a few minutes then turned it back on. The green ON light lit, there was a click then the green light went off and the red standby light on.
Removing the rear cover we noticed fuses FU202 and FU204 were blown. We replaced the two STK932-110 ICs with Sanyo STK932-180 and resoldered the entire power supply board (PS). We tried turning the set on and it was the same as before - green ON light, a click, then red standby. The two fuses were not blown this time. Several more attempts saw no changes.
The D915 LED was lit on the PS and the D923 LED was lit on the convergence amp assembly (CAA), indicating a problem with the CAA. Thinking there may be more problems than just the ICs, we ordered a new CAA from Pioneer. We installed that and once again tried to get the set to work. It still didn't. Green ON, click, red standby.
There was one nagging issue that haunts us - when disconnecting the old CAA, a screw was left in the metal ring holder and that was laid over the video board to get the wires out of the way. When reconnecting the new CAA that screw dropped into the video board.
It seemed to vanish! In order to find it, we had to remove the entire video rack and that required the disconnection of several connectors. After the missing screw "reappeared" we put everything back together and plugged in all the connectors. But there was one connector on the video assembly that had no cable to plug into it. In the service manual there is an arrow from it that points to "To AUTO COVER". If there is a cable that is supposed to be connected to this, it has disappeared. We must have looked for 20-30 minutes for it! So, for the moment, this connector has no cables connected to it.
So after spending hours resoldering the PS, time and money on replacing the ICs and then spending another $315 on a new CAA, we are right where we were when the set turned itself off three weeks ago.
BTW, the set was disconnected from 120v power and remained so until after the ICs were replaced. When they didn't work, the set was unplugged again. After the new CAA didn't work, we once again unplugged the set. So if it has to remain plugged in for any length of time, this has not been happening.
It seemed to vanish! In order to find it, we had to remove the entire video rack and that required the disconnection of several connectors. After the missing screw "reappeared" we put everything back together and plugged in all the connectors. But there was one connector on the video assembly that had no cable to plug into it. In the service manual there is an arrow from it that points to "To AUTO COVER". If there is a cable that is supposed to be connected to this, it has disappeared. We must have looked for 20-30 minutes for it! So, for the moment, this connector has no cables connected to it.So after spending hours resoldering the PS, time and money on replacing the ICs and then spending another $315 on a new CAA, we are right where we were when the set turned itself off three weeks ago.
