Today I received the Disney WOW Blu-Ray calibration discs and carefully calibrated the Standard and Custom Picture Modes.
I set-up Custom to be my default setting for most material with deep blacks and minimal blooming (really only an issue oxx-axis with credits and white logos on black backgrounds), and with the Standard setting being used for cases where I want brightest picture possible.
I'm happy to report that most of the settings were very close to factory settings. The set was calibrated in a darkened, but not blacked out viewing room. I had one paper tower lamp from ikea with 3 low wattage bulbs, and vertical blinds behind the viewing position closed with slight light leakage. This represents a real-world versatile viewing environment for me. I won't be playing at the beach front cottage, or in a pitch black home theater.
Picture and contrast were based on standard test screens maintaining whiter than white and darker than dark values. No clipping or blooming. Brightness was closed to maxed out in both cases, and brightness was a few points lower than default. I looked for any grayscale difference in the reference 0 black region - straight on and at moderate horizontal viewing angles.
I left NR on after noticing that the filter removed digitized film noise from the opening spy hunt scene in "From Russia With Love" on the recently released. Blu-ray Bond 50 with minimal negative effects. The Black Corrector, Contrast Enhancer, Dynamic Control, and Auto Light Limiter negatively affected the test performance on the WOW test screens when using the settings listed below.
Gamma was set to +1 to achieve a reference Gamma of 2.2. (Edit: Set to 0 with Light Sensor = Off to give approximate Gamma of 2.2)
Motionflow is a tricky creature. On a lot of digital content, the effect was nearly impossible for me to observe other than Clear was dimmer than Standard, and Clear Plus was dimmer than Clear. Impulse flickered terribly. And Smooth seemed close to Standard. However, on 24p film content, Smooth had that mild "Soap Opera" effect that I have strongly disliked on Samsung sets in Costco.
Motionflow is somewhere between Standard and Clear IMO. Clear Plus takes too much of a brightness hit. Clear helps with the halo effect.
Color Temp seems about ideal at Warm 1. Most 929 settings were Warm 2, and some reviewers said to give it some time to get used to the orange cast. It's something in the Warm 1 to Warm 2 area for sure though.
The remaining items that I need to evaluate are Motionflow and White Balance. Motionflow is somewhere between Standard and Clear IMO. Clear Plus takes too much of a brightness hit, and Smooth has that effect that I am utterly despise. I think we'd need a pro to properly set the white point settings, but I'll look use white paper to adjust the RGB Bias here in a day or so.
The horizontal viewing angle on my set seems excellent IMO. I can get off axis about 40˚ before I see any effect on the color. I also feel that screen uniformity is excellent with R, G, B, and with real world material.
I'll update these settings once I have a chance to put some time in with Live Color, Color Temperature, MotionFlow and White Balance.
These settings were very carefully done, and should get you pretty close to start optimizing for your room, viewing position, source components, viewing material, and personal preferences.
I'd love to hear what's working for everyone else.
EDIT v1.1: Updated Color Temp setting to Warm 1 for both profiles and corrected LED Dynamic Control to ON.
EDIT v1.2: MF increased from Standard to Clear to reduce halo effect. Trying Backlighting at 1 with Custom profile.
EDIT v1.3: Slight tweaks to low backlight profile. Adjusted Gamma to 0 from +1.
EDIT v1.4: Estimated White Point settings from HDGuru Calibration Report
EDIT v1.43: Warm 1 - Warm 2. RGB Gain and Bias adjustments
EDIT v1.5: Picture & Brightness optimized using Warm 1 and Light Sensor = Off. RGB Gain TBD
XBR Settings v1.5.pdf 49k .pdf file
Edited by jmjunker - 10/4/12 at 5:35pm
I set-up Custom to be my default setting for most material with deep blacks and minimal blooming (really only an issue oxx-axis with credits and white logos on black backgrounds), and with the Standard setting being used for cases where I want brightest picture possible.I'm happy to report that most of the settings were very close to factory settings. The set was calibrated in a darkened, but not blacked out viewing room. I had one paper tower lamp from ikea with 3 low wattage bulbs, and vertical blinds behind the viewing position closed with slight light leakage. This represents a real-world versatile viewing environment for me. I won't be playing at the beach front cottage, or in a pitch black home theater.
Motionflow is somewhere between Standard and Clear IMO. Clear Plus takes too much of a brightness hit. Clear helps with the halo effect.Color Temp seems about ideal at Warm 1. Most 929 settings were Warm 2, and some reviewers said to give it some time to get used to the orange cast. It's something in the Warm 1 to Warm 2 area for sure though.
![Wow: World of Wonder [Blu-ray]](http://cdn.avsforum.com/1/11/50x50px-ZC-1166fb14_B00462PTDQ-51E0ByQYHsL.jpeg)
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
