AVS › AVS Forum › Audio › DIY Speakers and Subs › Stereo Integrity's new HT Subwoofer
Stereo Integrity's new HT Subwoofer - Page 35
post #1021 of 1707
Originally Posted by djkest View Post
Also, anyone ran a 2 ohm load on 1 channel of an EP4000 or EP2500.. ? Will it be happy?
It will be fine. 2 ohm stereo load is the same as running 4 ohm bridged.
post #1022 of 1707
Lol! You guys talk like d4's are inferior to d2's. Heh.
post #1023 of 1707
They're ugly step children only loved by inadequate amps.
Keep your D4's on your side of the tracks and their won't be any probs, broseph....
post #1024 of 1707
The higher impedance actually requires stronger amps but .... okay. wink.gif
Newb.
post #1025 of 1707
Going dual opposed, it makes sense for me to go D4s, with the option for another dual opposed D4s later off an EP4000. Plenty of power for these. I'll never need to hit over 100db much throughout the frequency range anyway. I don't have the place for 120db of awesomeness, yet.
post #1026 of 1707
The D4s could be wired for 8 ohms or 2. So obviously running Dual Opposed with a sum total of 4 ohms would work bridged mono on many amps, or running 2 ohms per channel. Conversely The D2s could be used stereo on the same amp.
I guess it just depends on what amp you are using and how many subs you want to run. Me, I want to run 2 subs at 4 ohms per channel, I know you get more power with 2 ohms but you also get more heat and distortion, and I figure even at 4 ohms most amps will provide plenty of juice.
post #1027 of 1707
post #1028 of 1707
My drivers were delivered today. I assume I should test them out to make sure they all work. What is the best way to go about doing that? Some of the KC guys were talking about using a 9 volt battery - is that the way to go? If so, how does that work again?
post #1029 of 1707
Just connect it up with the positive and negative ... or whatever and it should sorta make a 'pop' sound and move forward or backward.
Oh and PICS!!!
post #1030 of 1707
is the SI HT 18 THE same thing as a Obsidian Audio 18??
here is why i ask this qestion
http://www.baniels.com/stereo-integr...-d2-subwoofer/
look at 2nd pic
Read more: New SI HT woofer specs and info - Page 29 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1031 of 1707
Nick told me in advance they would be shipped in an Obsidian Audio box (same owner). Probably didn't have any SI HT boxes printed yet.
http://www.baniels.com/stereo-integrity-si-d2-subwoofer/
look at 2nd pic
post #1032 of 1707
look at 2nd pic
Although they might look alike, the voice coil and the suspension stifness and such is what makes it the SI HT and not your typical car driver. It digs deeper!
Keep cranking,
Robert
post #1033 of 1707
9V is a good way to see if the sub is wired correctly internally(+ is actually the + and - is actually the -). When you put the 9V to the sub(+ to+ and - to -) it should pop out. If it sucks in then it is reversed. You should also put a 10Hz sine wave through it and make sure its not making any unwanted noises at decent excursion levels.
post #1034 of 1707
Originally Posted by robertcharles View Post
I just saw this. With smaller sealed box, you get protection from bottoming. Those measures are external with single panel sides?
Yeah, thats what i was thinking. 1" MDF, external dimensions, since its downfiring id probably want to sink the subwoofer either 1 or 2", but im not *as* concerned about height.
post #1035 of 1707
look at 2nd pic
As has been said, the HT18 is related to the Obsidian but it is much more compliant, the VC has been modified and the shorting ring has been added as well for additional linearity. Really, the only things similar about them is the "looks"
post #1036 of 1707
These things are light! Well, light compared to the only other 18" driver I've ever picked up, which was the ported Captivator driver.
I checked them all with a 9 volt battery and all were wired correctly, and then tested them with a 10hz test tone turning the volume up to around -8. Lots of movement, very smooth, dead silent - no rubbing or scraping noises. Nice!! smile.gif Sad thing is I had to box them back up while I wait on the flat packs.
post #1037 of 1707
Yyyeeesss...carp!
post #1038 of 1707
That picture is funny! Your poor little dog is cowering in fear of your new toys!
post #1039 of 1707
post #1040 of 1707
where did you buy the flat packs from??
i live in k.c. an woul love to see this when finished
post #1041 of 1707
post #1042 of 1707
Still struggling to talk yourself out of buyin 8 of these or the Daytons, eh?
post #1043 of 1707
is he going to use the 4.5 sealed or what box is carp going to use?
post #1044 of 1707
You look small compared to that driver...I know I posed myself beside my 8. Perhaps the worst mistake I ever made to grace the interwebz...
post #1045 of 1707
For this driver, 4.5 is happy, per driver. at 600 watts. You want to go higher? cut the box smaller and give it about 1,000 watts. It will still be happy around 3.5-4 cuft per driver
post #1046 of 1707
Haha, I figured if you put a pic up with you with your drivers I would do it too.
To get an idea of scale, I'm 6'1" 170.
post #1047 of 1707
finished dual opposed pair up yesterday. really happy with how they turned out. These pics are all in my thread but i figured i would post them here as well. listening impressions to come. I like what i hear so far.
post #1048 of 1707
Nice Brian!! Those look great, can't wait to hear your impressions of how they sound.
post #1049 of 1707
WOW!!! Brian,,,
What a beautiful job on those...They look AWESOME!!!
GREAT job!!!
Thanks for sharing...
post #1050 of 1707
THANKS!!!!!!
I did a little more level matching and some testing. Im sure they arent broken in yet, but heres my initial opinion:
I just watched the final battle scene in The Avengers. Also the Lightening strikes and Pods Emerge from War of the Worlds. Both scenes flickered the clip lights regularly.......I have never been more afraid of breaking my house or having the cops called on me!! And thats with only 1 amp, 300 watts per driver. I cant wait to send 1000 watts at each of them!! Actually, im kinda nervous........
