AVS › AVS Forum › Audio › DIY Speakers and Subs › Stereo Integrity's new HT Subwoofer
Stereo Integrity's new HT Subwoofer - Page 63
post #1861 of 2212
Originally Posted by Archaea View Post
Beast do you have a build thread for your sonotubes. I'm curious how you made the end caps and the feet?
This was the thread where they were basically started as LLT's:
http://www.avsforum.com/t/1388343/how-easy-to-source-parts-and-build-a-quick-llt
All I did to convert them to DO is pull the port out and shorten the enclosure and build a new endcap to house the second woofer, it was pretty easy smile.gif
Gear mentioned in this thread:
post #1862 of 2212
Oh, and for the base and feet, I literally got 8 huge lag screws that you usually see holding decks on to the sides of houses, and 8 4" spacers that the lag screws pass through the middle of them and screw into the bottom platform.
post #1863 of 2212
Thanks all.
Headed out to pick up two 3' x 24" tubes and two 1.5' x 24" tubes. Total ... 122.00. biggrin.gif
Now I need to find someone to cut the circles, or buy a router. I don't have a garage, well I do but its a gym. I cant believe how inexpensive this is, and how well they will fit in my space.
How much space needs to be between the down firing woofer and the base plate or ground?
post #1864 of 2212
I j
I just happen to have an 8ft piece of clothes/coat hanger dowel rod thats been sitting in out living room for a couple weeks so ill probably use that.
post #1865 of 2212
Originally Posted by pdxrealtor View Post
Thanks all.
6 -8 inches is usually enough
post #1866 of 2212
I j
That will work perfect, just give the driver at least 4 inches or so.
post #1867 of 2212
LOL! I'd like to go with as least amount possible. So.... is four doable is it more like 6-8?
I forget, do you get more DB ( I know very minor but none the less) with or without the base plate? I'm on concrete slab with pad and carpet.
post #1868 of 2212
my baseplate is 4 inches, and it works perfect. you gain like 1/2dB or something adding the baseplate so the difference is minimal enough you need not worry about it.
post #1869 of 2212
So beast.... Couple questions.
1) how much does your top baffle over hang the tube? I think you said they were 27" but im not sure how big your tubes are.
2) you say quad 18s. Assuming but want to double check. Thats two per tube right??
Look where i just came from! biggrin.gif Two 3 footers for dual opposed and two 1.5 footers for singles to smooth out the FR.
Edited by pdxrealtor - 9/6/13 at 3:10pm
post #1870 of 2212
Long day..... finally back at the office.
With two dual opposed cabinets and two single cabinets I'm thinking it might be best to go with two separate amps. Does anyone have any other ideas?
No matter how I configure it unless I take one driver from a dual opposed and connect it with the two separate drivers on the other side of the room I don't get an even load from a single amp.
post #1871 of 2212
I would use two separate amps since you are spreading them out. I built 8 sealed sonos before.
post #1872 of 2212
Alright pdx, what are you up to? You’all goanna build some big a sono’s? biggrin.gif
post #1873 of 2212
Ya I'm not seeing any other real 'good' way to do it. Crown has the 1500 and 2500. Definitely open to suggestions.
I was at a speaker store the other day and they brought up Crest amps. I've yet to research them.
post #1874 of 2212
I couldn't resist. For 110.00 I just got enclosures for 6 18" woofers. Already have the mini-dsp, the MDF, the dowls.... did I mention 110.00 for enclosures? eek.gif
EDIT--- Think I'm going to treat myself to a router and whatever it takes to cut circles!
post #1875 of 2212
Cool! Might you start your own thread.. Plenty of us will be glad to help you out. cool.gif
Yip! that's what it takes and a jig, that can be made though.
Edited by steve nn - 9/6/13 at 8:02pm
post #1876 of 2212
It's on the list. 8:02 PST and I'm sending out comps and drawing up paperwork. Guess I'm being paid back for two weeks of 'down' time. smile.gif
post #1877 of 2212
might want one of these as well
http://www.parts-express.com/pe/showdetl.cfm?partnumber=365-250
post #1878 of 2212
That is exactly what I need. But it's too small. I need something that will cut at least 25". Thanks though as I'm sure there are exact models that go bigger.
post #1879 of 2212
post #1880 of 2212
post #1881 of 2212
You can also make one (adjustable) for a few dollars if you’re inclined? Take a few lengths of 1/8” and put two running slots in each one and then wing nuts.
Edited by steve nn - 9/6/13 at 8:54pm
post #1882 of 2212
post #1883 of 2212
OK on amps, the crests are a good option. Right now I am currently running 4 si's wired to 4ohm per channel of a peavey 7500ipr2 you could literally buy one epx4000 or ep4000 per pair of drivers, or even the new Beringer 4 channel I nuke. Also, wiring 6 drivers, three per channel on the peavey would actually be almost perfect. If you can figure out the wiring.
post #1884 of 2212
If I wired three per channel then Id have a third driver on the opposite side of the room of the dual opposed enclosure. That would make eq ing the single enclosure frequency smoothing or near field subs impossible.
post #1885 of 2212
OK then. Wire the two dual opposed boxes to a single 4 ohm load, and the two singles to an 8 ohm load, 4 on one channel of the peavey and the nearfields on the other. Yes they are at a lower impedance but with just two, the power will still be about t the same as each sub is getting on the other channel in 4 ohm
post #1886 of 2212
Gotcha.... it is OK to use the same amp wired in stereo and use each channel , one for near field and the other for the dual opposed. I could use the cv500 in the same way with 4 ohm/2ohm load configuration.
post #1887 of 2212
The gains will be different, and on the CV I don't know if the channels are fully discreet, but on the peavey they are.
post #1888 of 2212
Yes, the gains. Thats not an issue though right?
Im really liking the peavy 7500 and the way it breaks down giving my drivers all ~ 1000 wats.
post #1889 of 2212
Nope, you should be good there.
post #1890 of 2212
Cool thanks.
You were going to try the amp in 4ohm mode and give your impressions over in Gorillas peavy amp thread. Did you ever get it hooked up with a 4 ohm load?
