AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic TC-P42C2 Red and Blue Lines
post #1 of 5
Attached is a picture of the problem I have with a Panasonic TC-P42C2. There is a band of red and blue lines across the screen.
Does anyone know which board causes this problem?
Anyone have a repair manual?
Edited by toy4x4 - 9/22/12 at 7:29am
post #2 of 5
Don't know which board, have no experience with this model
Here is the service manual with troubleshooting etc.
http://elektrotanya.com/panasonic_gph13du_chassis_tc-p42c2_plasma_tv_sm.pdf/download.html
post #3 of 5
Fixed 2 42x3 which was the 2011 cousin to this 2010 model with similar stripe issue. An A board replacement fixed both. It was something with the image processor . The a board is the one with all the inputs. This issue should be on all inputs.
post #4 of 5
Hi, I have the exact same issue as you on my panasonic TCP58vt25 plasma. Just start yesterday. The set is barely 2 years old.
Did you get yours fixed? What was the solution to the problem? How much for the repair? Just need to know what I'm up against.
Rob
post #5 of 5
Same exact thing JUST happened to my Panasonic. Did you ever get your fixed? What was the issue and how much was the repair? Thank you!
