I got my JVC 48WP30 delivered today.
Picture quality is great on DVD's. I have the Denon 1600 connected through S-Video and Component cables.
It seems component input has a problem. I'm not sure how to describe it, but I can see some horizontal lines, similar to scan lines. Actually, they are wider than scan lines. It seems like there's a different in brightness on this lines. It's very easy to notice on the blue screen that comes up when you stop the movie on the dvd player. It's very distracting on brighter scenes.
Also, when I switch to progressive output, these lines begin to move and the problems get a lot worse!
Clearly, the problem is with component inputs since the picture quality with s-video is great.
I remember that Meiche mentioned a problem with 1080i pictures being displayed on this set. I saw this problem myself on one of the display sets in Best Buy. On the same thread, he mentioned he talked to a JVC representative that told him the problem could be solved on the service menu. He mentioned that you have to correct the set-up of the input.
I don't have HDTV yet, but I'm starting to wonder if the problem I have is the same problem Meiche and I saw on display sets, since both use component inputs.
Well, on the same thread, another guy talked about entering the service menu through setting the sleeper to 0, pressing display and v. status at the same time. Meiche told him that didn't work with his set. But it worked on mine!!
So now, I have the service menu, but I have no idea how to solve the problem.
So, now to my questions. Has any owner find this problem with component inputs when using a DVD player? You can notice this by comparing the picture with the S-Video input. Also, has any owner played with the service menu? I didn't play with it, but just by looking at it, I couldn't find anything related to inputs.
Well, any help is welcome!
PS: The problem may be on my DVD player. I have to test it at a friends house.
