AVS › AVS Forum › Audio › Speakers › Speakers - Confused
Speakers - Confused
post #1 of 4
Please delete this post - its been duplicated. Thanks in advance.
Tim
Edited by e485926 - 9/22/12 at 8:59pm
post #2 of 4
I'll give you two options on the opposite ends of both price and ability to play reference level, but both will sound very good for the price.
Extreme Budget Pioneer System (Max SPL around 95 - 97db)
Front http://www.newegg.com/Product/Product.aspx?Item=N82E16882117403 $119
Center http://www.newegg.com/Product/Product.aspx?Item=N82E16882117404 $49
Rear http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405 $49
Sub (x2) http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026 $400
total system cost $620 shipped.
Mid Budget BIC system (Max SPL around 116db)
5x http://www.amazon.com/BIC-America-FH6-LCR-6-5-Inch-Frequency/dp/B0015A8Y3E/ref=sr_1_2?ie=UTF8&qid=1348372527&sr=8-2&keywords=bic+speakers $550
Sub (x2) http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078 $600
Total System $1150 shipped
post #3 of 4
Thank you for your post. The front two speakers, i need it to be hanging on the wall. Do you have any recommendations for such type?
post #4 of 4
The BICs come with mounting brackets attached for wall mounting. They are also a sealed design, so no port concerns.
  Back to Forum: Speakers
