AVS › AVS Forum › A/V Control & Automation › Remote Control Area › MX-980 Downlading data to the remote impossible
post #1 of 3
Hi I've bought a MX-980 in 2008 and never had any problems with it for four years. I recently changed of cable supplier and have a new HD-PVR to program in the remote, so I started to program it. My problem happened when I tried to download the data in the remote a window popped;
"Connecting to MX-980 device
Loading System..."
That was okay untill another window popped;
"Not Exist RCManager.exe!"
What does it mean?
The last time I tweaked this remote was in early 2011 with my old (dead) PC. Is this a problem with my device or the editor?
I performed a live update on the editor but it still give me the same error message when I try to download the data to my remote.
I'm kind of screwed here since all my A/V devices are in a closed cabinet and I use a MRF-350 to convert the IR to RF.
I need help!
Thanks in advance.
post #2 of 3
What does it mean?
Click here to some some post at Remote Central that may help. Some more AVS post here.
post #3 of 3
Thank you sir your reply was really helpful I got everything working again. biggrin.gif
  Back to Forum: Remote Control Area
