AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Reverse Firmware update on Panasonic BD-30
post #1 of 3
I downloaded and followed the instructions to update the firmware on my Panasonic BD-30 to version 3.1 using a burned CD. Now I can only get 2 channel stereo output. The player worked fine until I decided to get cute and "improve" the situation. Any ideas on how to reverse the process or fix it?
Robert
post #2 of 3
Welcome to AVS. Mods ask that you post all questions in the owner's thread in the player. There is no way to revert to a previous version of software. If you are getting stereo, make sure that Secondary audio is turned off. Also make sure the player is set to bitstream. If you run through a receiver, make sure it is set to Amp and not TV (or however your receiver kists it). If all else fails do a reset of the player. That has been known to work.
S~
post #3 of 3
This thread is locked
