Taking a lead from post #2 (http://www.avsforum.com/t/1430470/cant-get-rcs-comcasts-dark-grey-ok-button-red-to-function-with-panasonic-50v10):
"Assuming you're using TV setup code 10650,
Press TV,
Hold Setup until 2 blinks
Enter 994
Tap Setup
Enter 24885
Press OK/Select
2 blinks for success"
This would be the protocol for setting various TV functions using the Comcast RC (platinum red button). I have already set my Yamaha's functions on the RC using the AUX mode button. So, that means that I now can control the TV, Yammy and SA8300hd from the RC. Is it now possible to also set functions for a fourth unit, my Panasonic BD-85 blue-ray player? I would think that if I can, that I would somehow have to use the "shift" key, but I need to know the protocol. Like:
What bd-85 set up code should I use?
And then what number do I enter after the two blink on setup hold?
Actually thinking of using these codes from here (http://www.hifi-remote.com/jp1/lookup/)???
n/a Blu-ray, DVD Video 1641 Panasonic MIX Combo 176 0 255 255 001F BF FB F2 FF 00 00 00 7F n/a EFCs 3
n/a Blu-ray, DVD Video 1641 Panasonic MIX Combo 176 144 255 0 001F BF FB F2 F6 00 FF 00 7F n/a EFCs 3
Press TV,
Enter 994
Tap Setup
Enter 24885
Press OK/Select
