Hello there,
I've been lurking here for quite some time and appreciate all of the expertise and discussions.
I'm in the process of upgrading my sound from an old (6yr) LG HTIB with a passive sub which cost $250 back then.
So far I have a Denon AVR 1713, which seems really nice and the discussions over in the Receiver forum support that.
For speakers, my instinct is to go with a box set. Basically I don't know enough to pick out individuals and have it end well. To that effect, I'm considering the following.
Definitive Technologies ProCinema 600 - $799
http://www.amazon.com/Definitive-Technology-ProCinema-Speaker-System/dp/B000TDENA6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1348480126&sr=1-1&keywords=definitive+technology+procinema+600
Energy 5.1 Take Classic Home Theater System - $399
http://www.amazon.com/Energy-Classic-Theater-System-Black/dp/B001202C44/ref=sr_1_1?s=electronics&ie=UTF8&qid=1348480155&sr=1-1&keywords=energy+5.1
My living room is about 16' x 16' and the system will primarily be used for watching movies and TV. Lots of Sci Fi, plus Kung Fu both recent releases and older stuff like Tron and Star Wars. TV is mostly the Science and Discovery Channels.
So, my question is, will I notice an improvement with the Definitive Technology over the Energy? Would I be better off buying the system piecemeal. If piecemeal, what would be recommended? I could stretch up to $1k if it would be worth it, I just wouldn't know where to put the extra money.
Thanks a ton!
-Paul
Thanks a ton!
-Paul
