I have used netflix from about the beginning, I noticed the BDs have "Rental" on most of them. I just got Skyfall tried to play it in the computer bd. I have PDVD12Ultra and checked the lossless option with my 7950 gpu, 990FXA UD3 board with 8channel but the audio is direct to the onkyo 608 via hdmi. I got audio and lists in the onkyo as master hd 7.1 as i expected but the audio drops out at some points, seems possibly at louder action , not sure , never happened on other master audio hd. have never had issues. i have used the iso as well (not this one, using directly from netflix rental bd) the plain DTS 5.1 plays just great,normal. but no matter how i set up, the lossless drops off now and then. at the ending of the lion's roar. and on the first parts intro chase scene , appears to be dropping for some continuous blasting or shooting. I checked for some loudness protection, but i played the latest Bourne which is quite loud , blasting etc. no issue, nor has there ever before been shut off. just this disk . i may be wrong about the only times it cuts off/drops audio and loudness, i changed the audyssey dynamic eq/vol controls among light , med, high, no effect i could actually tell. only did a short time test with this. changed hdmi cables to brand new....no change. check and re check the settings , though they are the same as with the other bd ISO and discs which work. any time there is some controversy , i dont know if i could have just gotten a bad disc where the audio track is not as good, or if it is a driver issue, (which i meticulously clean installed the Realtek 2.70/hdmi and brand new catalyst 13.1-i rolled back from the 13.3beta 3 i had used for a week, just in case)
Just my 2¢, since i have usually been successful with the amd/audio from my asus eah5870s v2 and those issues to this sapphire 7950 and all of its supposed audio upgrades for multi monitors.. i am only connected to 2 with audio through onkyo to one particularly for BD movies
