AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › TV for Xbox 360
TV for Xbox 360
post #1 of 4
Want to get my son a tv for his Xbox in his room for Xmas. Best buy Insignia 32 in LCD that is 60 MHz 720p. The guy at store said I really need 120 MHz. I am clueless so here for your thoughts.
post #2 of 4
I'd recommend asking around in the LCD forums - probably a wider range of knowledgeable people there. If I knew much about LCDs, I'd offer to help myself. Best of luck.
post #3 of 4
Don't listen to anyone at Best Buy because they're trying to get your money, not give you good advice. Insignia is a knock-off brand so you have a higher risk of ending up with a bad unit. I'd stick with Samsung, LG, Vizio, Panasonic, Sony, etc. Brands you know. Then again, a good price might be worth the risk of an off brand.
The Wirecutter has a good couple of recommendations: http://thewirecutter.com/reviews/best-small-tv-samsung-un32eh4000/
Otherwise, as Skip said, the LCD forums can be a great place to find what might work best for your needs.
post #4 of 4
Yeah, as far as I know, Insignia is just Best Buy's own brand. If you were looking for a bigger screen, I'd recommend plasma, but at 32", you're out of luck. Happy hunting - I know the forums here helped me a ton when I was researching my TV purchase.
  Back to Forum: Xbox Area
