My friend gave me a Boston Acoustics VR500 (10") subwoofer that seems to have an issue. I'm not sure if it's worth fixing or if I should just trash it. The subwoofer is for my 7 year old daughter's room, so I'm not looking to spend a lot on fixing it. When I play a test tone through the receiver, the subwoofer makes a distorted crackling sound. I tried it on two different Denon receivers and it does the same thing. I don't think it's a grounding issue, as I connected another subwoofer to both receivers and it sounds fine.
I don't have any DIY experience with speakers or subs, so I'm not sure what I should be looking to replace. I looked at the cone itself and there doesn't seem to be any damage. I'm planning on unscrewing the speaker to see if there is something else I'm missing. Any ideas?
VR500.JPG 90k .JPG file
