AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Buying a 60-65" Plasma and undecided on what to buy.
post #1 of 3
My mother recently had both of her old CRTs recently die. Based off an earlier thread I picked up the Panny 50U50 for her bedroom.
I now have to figure out what to do about her living room. Either way the purchase will most likely be local from Best Buy.
Option 1 - I move my Panny 58V10 over to her house. I then upgrade to a 65" Plasma.
Potential Issue - I don't have the original packing materials since BB took them when they dropped off the set 2+ years ago. Also i don't know if I will be able to stand it up in her SUV, Hyundai Veracruz, so getting the TV over there may be tricky. I might have to rent a cargo van to move it.
This then leaves me with the decision of what TV to go with for me. Upgrading to a 60" seems like a waste so I would probably go for the 65". It looks like Panny options are getting tougher to find locally through BB. The ST is sold out and I don't know how the GT50 compares to the V10.
In my house our viewing is mostly FiOS via TiVo and the occasional DVD from Netflix from around 12-15 feet.
Option 2 - I just pick her up a 60" for her living room.
The only downside is I don't get to upgrade. I wasn't necessarily in a rush to upgrade though since I have been happy with the 58V10. I also don't know if I want to spend 3k on a TV which is what it looks like it cost me for something like the 65V50.
This then leaves me with the option of what 60" I go for her living room. Some of the IR reports for the Panasonic sets concern me a bit just because I don't know how her viewing habits are.
She is similar in that she also has FiOS via TiVos though I will have to push her to HD over SD now. She never watches movies though. She doesn't have any direct sunlight issues but she does tend to leave the lights on when she watches and does a good amount of daytime viewing.
I guess in short how do the current Panasonic sets like the GT50 compare to the 58V10.
For her I would probably set a budget of $1600 or so since she really doesn't need any advanced features and wouldn't use them. I just want something that looks good and she will be happy with, but not something she needs to worry about babying.
Thanks guys.
post #2 of 3
It looks like you want to stic with Panasonic, but ahve you thought of Samsung? They have a 60" PNE6500 that fits into your price range of ~$1600. From what I have read the Samsungs this year do a better job of handeling lower quality feeds than the Panasonics. This isnt fact per se, just posts and such I have read on the forum...the 60pne6500 has the same panel as the 7000\8000 without the dual core processor and other "upgrades" those models get. It still has built in wifi with access to the apps, so that shouldnt be an issue. its probably a good baseline TV for most who are look for an alternative to the ST.....
If you are in no rush to upgrade, then maybe now isnt your time...I would probably get soemthing lie an ST\6500 for her, then wait possibly until next year when the new models will be out.....
post #3 of 3
Unless she is serious about picture quality, I would be looking at LCD/LED because of potential IR (if she watches any kind of news/sports/ticker/4:3 type content). I just would not trust either of my parents to "manage" IR/burn-in (debatable if management is necessary, but an expensive mistake to make).
That said, if I were you, I'd be moving my old TV over and upgrading to a 65" ST (or GT/VT if you want those features).
