Originally Posted by
4Lester
Anyone else having an issue with the sub not playing? The system plays it during the MCACC set up but that is it. None of the sources or settings have solved the issue? Any ideas?
Overall not super impressed with the unit, UI from 1988, network function run like on dial up at best,
AirPlay is not stable...I can't really speak for the sound yet because the sub is missing...
Hey fellas! Some really informative posts in this thread. Found the answer to my (and everyone else's) Pandora issue! Thank you! But I haven't seen anything about an Airplay issue I am having except for 4Lester saying "Airplay is not stable" For me, Airplay starts up just fine, show the "Successfully connected to network" message, but then after about 2 seconds the music just stops! Hitting pause and starting back up doesn't work. Only way to try it out again is switch inputs on the receiver and try airplay again...only the same thing happens. Two seconds of play and then stop.
Anyone else seeing anything like this? All other network functions work fine...internet radio, check...DNLa, check...pandora, used to work until they changed their security...just Airplay, broken?!?! Lemme know what you guys think, thanks!
