AVS › AVS Forum › Audio › Receivers, Amps, and Processors › What is the difference between an AV receiver and a Power Amplifier
post #1 of 3
I know one difference is av receivers have a tuner for radio but what makes a power amp different?
post #2 of 3
An AV Receiver is a one box solution that performs many functions. It has a tuner, AV Processor, Audio decoders, DAC's , a pre-amp section and finally a power amp section. All these functions can be purchased separatey in different components or on one chassis - an AV receiver! A power amp simply amplifiers the signal - it cannot even control it. Therefore most power amps without a pre-amp or processor (to decode an control) are useless.
Hope this helps.
post #3 of 3
asere -- you might want to read through the AVR FAQ stickied at the top of this forum: http://www.avsforum.com/t/968859/avr-faq
