AVS › AVS Forum › Audio › Speakers › Bose 251 outdoor speakers
post #1 of 2
I just recently purchased the Bose 251s and noticed that there is a "rattle" when there is a lot of bass. Is this normal for these speakers or did I get a bad pair.
Also, are there better outdoor speakers than the Bose that are in the same price range?
post #2 of 2
I'd think it would be real easy to overdrive outdoor speakers...are yours only rattling at high spl's? If so, maybe you're reaching the woofer's limits. More likely, it's probably just a grille vibration or a wire inside the speaker rattling against something. I don't know how hard it would be to open them up for a look see. Worst case scenario - a woofer is shot. Since they are new and under warranty, I would just take them back for another pair.
As for your second question, they are in a pretty crowded field. I'd just recommend carefully comparing what's available and buying what you like.
  Back to Forum: Speakers
