Hi Guys,
Im soon to be building a house and i want to wire up the house for all my A/V distribution, plus home networking, security, possible future automation added using Control4.
Im wondering what the best solution is? At the moment my idea is to have everything in the one place then distribute via a 4x4 matrix switch (Atlona) to 4 TV's. Im planning on having everything rack mounted. Also in the rack will be a 16 port gigaswitch and a computer server.
I have just found these new sony receivers. They have the ability to distribute 2 zones of A/V simultaneously, but my problem is that isn't enough.I want 4 simultaneous outputs.
Should i get a cheaper amp purely to run the surround sound in 1 location (theater room), along with the WHA in separate zones?
Any comments ideas would be great? cheers,
PT
PT
