AVS › AVS Forum › Audio › 2 Channel Audio › Low budget build
Low budget build
post #1 of 4
Hello everyone, this is my first post here so please be brutally honest (I need it).
I'm currently in school, and as soon as I graduate I plan to move far away to get a PhD. Through a series of fortunate circumstances and generous friends/family, I do not actually own any furniture. Because of this, I am trying to avoid purchasing anything that I can't either take with me or sell before I move.
I live in an apartment building and don't want to disturb my downstairs neighbors with a subwoofer.
My furniture is arranged in a way that I could accommodate a 5 speaker system.
I will be using this system mostly to listen to music, watch steamed movies from hulu/netflix, and watching hdtv through an antenna.
With all of this in mind, I'm leaning towards a 2.0 system. The surround speakers seem like they would almost never be used. Any subwoofer of decent quality/volume will probably give my neighbors a headache, so I'd rather go with two floorstand speakers.
As for the price range, I'm hoping someone can provide some insight. I know that for computer components there are certain performance/cost plateaus that you want to meet, but not exceed, in a build. Is this the same for speakers? Or does performance/cost degrade at a relatively constant rate? I'm hoping to spend ~$200 ( polk monitor 70 perhaps? ), but I could pay up to $300 ( veritas 6.2 or cf 50 perhaps? ) if it provides better value.
Frustratingly enough, I love my bass. However, I love not being evicted even more. I would like my speakers to provide relatively good quality sound at low frequencies, but not so low that they would rattle my floor.
I don't have a receiver yet either and have absolutely no idea what to get. I don't think I need any special features, I think I want one with a digital audio in (from the TV), at least 2x (3x ideal) hdmi inputs from my computers, and a hdmi out to provide video to the TV from the computers.
post #2 of 4
For speakers, consider Infinity Primus P363.
Plenty of AVRs out there with 3 or more HDMI ports, plus room correction. I'd recommend whatever's on sale at Best Buy this week that meets your connection needs.
post #3 of 4
Home theater receivers by Yamaha and Denon are both good choices for mixed music/home theater systems. Onkyo used to be a solid choice, too, but they've had a lot of HDMI quality control complaints with their recent models. Check out the Yamaha V373.
I don't have any speaker recommendations, but I would look into getting both full range speakers and a nice pair of headphones. If your sources are mostly OTA and online, going with a better 2.0 music-centric system rather than 5.1 is probably the right move, and you can get a lot of bang for your buck with headphones for when you want to turn the music up or watch a bass-heavy movie.
FWIW, as long as you have a thick skin, it takes a lot to get evicted for playing your music too loud. If you don't mind your neighbors hating you, go nuts. smile.gif
post #4 of 4
+1 on the Infinity Primus recommendation. Great budget towers and they dig fairly deep. It's always better to have a subwoofer in the mix but these towers are great for the price. For AVRs I would check out last year's Denon or Yamaha models. I'm not sure if you're interested in Airplay or networking but the Denon 1612 wouldn't be a bad choice. If you want networking you would have to step up to the 1912 or 2112.
