Not getting at anything. I just think there is a better way to do it. It's really simple, not complicated. Wide braces. I just need some figures/diagrams to explain why it works better. Maybe your braces already do what I'm thinking about.
The image is just a diagram I was able to find on the internet about slender column design.
Here is a better one I managed to find: http://www.ejsong.com/mdme/modules/fea/Buckling.GIF
Because the panel is "fixed" at the corners, we have the second from the left case.
Now look at this: http://1.bp.blogspot.com/_721bPXg5FDs/TVA9Q1RzCQI/AAAAAAAAAME/BN0Zp1e11oM/s1600/fig.jpg
By adding a cross brace you add 1 or 2 or nth nodes to the panel thus reducing the effective L that can vibrate. That's because a dowel or a 1" wide brace acts like a node. If you use braces that are say 3 or 4" wide (even if you want it light, just cut out the middle portion) then you aren't adding a node, you add a fixed brace which reduces L again by 0.5. I just can't find the last diagram I need to explain that part.
It's why holey braces are so effective. But I'm proposing something smaller than holey braces, yet close to the same effect. Nothing new, many have done it I'm sure. Possibly everyone does it. I just don't see many pictures of it. I usually only see 1" strips, dowels, or holey window braces. The best brace for the weight is a 4" wide stip, imo.
