AVS › AVS Forum › Home Entertainment & Theater Builder › Outdoor Theaters › Outdoor Theater HDMI Question
post #1 of 4
I have just recently purchased a screen for the backyard and looking for ideas on how to get a signal to the projector. Is it possible to transmit everything wireless thru a HDMI wireless transmitter. I would have one wall but pretty much a straight line of site just over 100 feet. I have searched a few things but not real sure what I should be looking for. I would only be using for movies and football games no gaming.
Projector Epson 720
Screen Gemmy 148
Comcast Cable box.
Any help would be appreciated.
post #2 of 4
You probably have a couple options, but that may be borderline distance for wireless.
Saw something like that on Amazon a while back that claimed 'up to 100ft', $179 currently:
http://www.amazon.com/Nyrius-Wireless-Transmitter-Streaming-NAVS500/dp/B005H3AU1Y/ref=sr_1_8?ie=UTF8&qid=1348761787&sr=8-8&keywords=Wireless+Hdmi
Alternatives may be just running a cable, Monoprice have 100' HDMI cables for about $100, or for slightly less you can do HDMI over CAT5/6 cables, total of maybe $75 for one of these and a pair of CAT6 cables:
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011012&p_id=6532&seq=1&format=2
Chris
post #3 of 4
Again, I recommend running a coax to your location and taking the cable outside with you. It's much easier to control the box from a few feet away, you only need a short HDMI and the coax is cheap.
post #4 of 4
  Back to Forum: Outdoor Theaters
